Question about Fujitsu Computers & Internet
Blue light flashing on ScanSnap S1100
Blue led flash intermittently, there seems to be no connectivity scan to computer (MAC)
5 Suggested Answers
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
  • 82 Answers
SOURCE: just moved computer to another room. Up and
you will have to reinstall the driver, it got knocked off line,
make sure you used the same port as before
Posted on Dec 20, 2010
SOURCE: my scanner keeps flashing and
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Posted on Nov 24, 2011
  • 1099 Answers
SOURCE: Blue light flashing on ScanSnap S510
The blue flashing like generally means that the scanner is doing a scanning operation.
Posted on Nov 30, 2011
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
Machine will not scan, blue light only blinks.
I have had this problem before also. What I ended up doing was shutting down my computer, turning on the scanner opening it all up so you can load it and ensure it is hooked up to the computer, restart the computer, open the program itself but then scan by pushing the flashing button on the machine, not using the program. I am not sure if yours will work this way or not but good luck.
Jan 03, 2013 | Fujitsu ScanSnap S510
Suddenly, my 500GB Seagate external hard drive couldn't mount on my iMac. It was working fine till yesterday. I connected them to the Mac USD port, and the light in the seagate is blinking... Any
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Aug 14, 2012 | Apple iMac 17" Desktop
Nov 29, 2011 | Fujitsu ScanSnap Manager
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Jan 26, 2011 | Fujitsu ScanSnap Manager
When i load the software the scansnap manager has a Red Circle with a Red X through it and the Blue light on the scanner is continuasly flashing.
As I was previously telling that there are two sub models in this category: S300 and S300M. The 'M' denotes for Mac. If you do not have this model your scanner will not work with Mac even if you install the correct drivers. These scanners do not use TWAIN drivers but use proprietary interface meaning you cannot use other drivers.
But there is a chance you may be able to make it work with Mac. Please let me know the version of your Mac and I'll see if can find some workaround.
Apr 24, 2010 | Computers & Internet
Cannot pair my emerson (em227) headset to my ps3
turn the device off (red LED flashes) then hold the button for atleast 10 seconds until both BLUE and RED LED flash aternatively... not just blue, pairing code is 0000
Aug 25, 2009 | Samsung WEP200 Headset
May 26, 2009 | Fujitsu ScanSnap Manager
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Computers & Internet Logo
1,251 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
