Question about windows.com
Updateing Windows XP to Window 8 near the end of the setup, a error message comes up; Windows 8 setup has failed to apply migration data. How do i rectify this.
  • windows.com Master
  • 1,824 Answers
I strongly recommend you to not upgrade from Windows Xp to Windows 8. First, you need Vista or 7 to do that with almost no errors.
When you enter the setup, did you check the checkbox which says to keep data or you didn't?
Posted on Jan 13, 2013
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My Dell V510 not working with my window 8
Hi,if your laptop built in windows is not windows 8 or it is a dos version you must download and check the user manual from dell.com to make sure your laptop support windows 8 and has hardware drivers and has minimum hardware requirement for it,
if its dos version and support windows 8 you must get the original version of windows and check the manual to install it;
if its a windows xp or windows 7 version so you must go to dell.com search your laptop serial number and find this message or google it
"how to migrate dell (serial number)laptop from windows 7 or xp to windows 8"
you know, installing a higher version of windows in a laptops is not looks like PCs,this is not a normal upgrade from windows installing process,and every good brands have their own ways to migrate to higher version of windows(of course some of them is looks like each other) but try to find it how to migrate,if you use normal update and skip the recommended points from your laptop manufacturer windows will getting noisy carshy freezy on your laptop
kind regards
Apr 18, 2013 | Computers & Internet
Failing to install anti virus on samsung netbook
Sounds like a virus has disabled windows installer.
Click Start/Control Panel/Administrative Tools/Services
When the services window opens scroll down near the bottom and look for Windows Installer. Double Click on Windows Installer then click START when it opens. Press Apply, Press Ok, then reboot and see if the problem is solved.
If not Reinstall Windows Installer:
The reinstall varies depending on your operating system so go to www.google.com and in the search box type "reinstall windows installer xxxxxx" (without the quotes and change xxxxx to your operating system such as Windows XP, Windows Vista, Windows 7).
Click the link and follow the reinstall instructions from Microsoft's site.
Apr 05, 2012 | Samsung NC10-14GW Notebook
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Initialization failed
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
After the game is successfully installed right click on the game shortcut or the game "AOM.exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply". (You can also try with the other options also)
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 19, 2008 | Microsoft Age of Mythology for Windows
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
windows.com Logo
55 people viewed this question
Top windows.com Computers & Internet Experts
David Payne
David Payne
Are you a windows.com Computer and Internet Expert? Answer questions, earn points and help others
