Question about Sport & Outdoor - Others
I want to build a skate ramp, however I need to know how to bend the wood into position?
    Problem Solver:
  • 16 Answers
For all but the top layer the wood should be bent with the grain. It bends much easier this way. The basic technique is to screw the bottom of your plywood in place, and have your helper(s) walk slowly up the transition bending it and holding it down with their weight against the frame as they go. Then you, and possibly others work your way up screwing in one row at a time. It's important to have the plywood held flush against the transition framing by your helper(s) when you screw it in. If you rely on the screws to pull the plywood flush, they'll pull through the plywood, or pull the plywood out of place.
Posted on Jan 13, 2013
Where can I get the ice skates for beginner under $100?
Ice skating is a kind of an aerobic exercise which offers positive effects on your cardiovascular health.
Ice Skates are boots with blades attached to the bottom. Choosing ice skates is the most important for ice skaters.
You have to check the comfort, stiffness, Quality while buying the skates.
The price also varies depending upon the material used.
You can get the good and comfortable skates for a beginner in figure skating store with affordable prices.
If you are planning to buy beginner ice skates and are looking for quality assurance, affordable price range, and wonderful deals then beginner skates range by Riedell can be the best choice.
Nov 14, 2017 | Sport & Outdoor - Others
How to build a skate rail?
You would need to be or know a welder, however I found this great site with detailed instructions etc.: http://diyskate.com/rail_01.html
Jan 17, 2013 | Sport & Outdoor - Others
In skating what is grinding?
Grinding is the name for sliding along an edge (such as a curb, bench, rail, coping, etc.) using your trucks instead of your wheels or deck.
How do you protect your ramp against the rain?
Wet damp conditions are not good for your ramp as the wood will more than likely rot after time. This should be taken into consideration before you make your ramp. When building the ramp, make sure to use galvanized screws or nails and use pressure treated wood, you should also paint it for extra protection.
Is it true that you have to change the surface of your ramp once or twice a year after your ramp is complete?
It all depends on the surface Skatelite lasts well over 4 years and so does polyboard if you look after it.
Jan 13, 2013 | Sport & Outdoor - Others
I want to build a dog house for my little dog but don't know if to use plastic or wood. What's a better option?
I would definitely use wood as the prime material to build a dog house. First and foremost wood will keep your dog warm in the winter. Secondly, it is much easier to build wooden dog houses compared to plastic.
Oct 25, 2012 | Dogs
How do I build a safe steam wood bender
Funny you should ask....I just built one! Here's a link. Very inexpensive and works great!
http://www.instructables.com/id/How-to-make-a-steambox-for-bending-wood/
Mar 24, 2010 | Hamilton Beach Steam Excel 14770 Iron
Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Mar 04, 2009 | Toys
Fuel sender unit
hello first thing get a flat block of wood 2x6 or 2x12and a floor jack get car ramps under the rear tires use jack stands for safety get the jack under your tank with a piece of wood snug dont crush the tank remove your straps that support the tank also the clamp at your filling tube work the tank down while letting the jack down better off with a helper much easier now at the top[ of the tank you need to remove fuel lines (make sure there is no pressure release at the fuel rail from your shrader valve) emmision lines, wires now take your tank out its easier to pour the gas out of the tank into pails its more managerable to work on at the top there is a lock ring it has flat spots that lock under 3 or 4 ears you want to tap the ring off so the small stops are going away from the ear use a copper or brass flat edged chisel or punch spray some wd40 on ring to help once the ring is removed your sending unit fuel pump assembly lifts straight up dont bend the float arm take it out on a angle that works now once you go to reassemble get your area clean where the rubber gasket sits on dont drop dirt or rust in your tank take some blue grease or lithium grease on the rubber so ithelps with the friction now insert unit back in tank install lock ring push down and get it started under the flat ears make sure all the sides are under now tap it to the locking position till it bottoms out on the stops reinstall all lines hoses jack back up install your straps take jack out leave on ramps have somone put the key to on position check for leaks and fuel pump sound if okay then drop down goodluck please rate
Oct 02, 2008 | 2004 Volvo S40
Sport & Outdoor - Others Logo
660 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
