Question about Running
Can you put running shoes in the washing machine if they are air?
    Problem Solver:
  • 16 Answers
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
Posted on Jan 13, 2013
Adidas SpringBlade running shoe tread splitting
there is not much hope for a solution to this problem as it is common to all shoes sold
Why adidas will not help is that they and all shoe manufacturers are aware that all shoes have a shelf life and if the shoe is not used in a short period of time after manufacturer the material used starts to break down and become unstable
it is the movement of the sole that sets the material and produces a long wear period but shoes ( and boots ) bought and stored will fail quickly with sole problems ( cracking, falling off , bits falling out etc )
Best advice is wear all your shoes on a regular basis for the first few months before leaving them in the cupboard and to get a retailer that will offer a replacement pair if the soles fail in a short period of time as a good will gesture for the customer
of course you can always resort to legal action as there is an expectation by the purchaser that the goods will last for a reasonable period of time regardless of expressed warranty period or not
Jul 31, 2016 | Adidas Mens Springblade Running Shoe
I replaced the timing belt on a 2003 Hyundai Accent 1.6 engine. I'm having problems starting the engine. What are the steps to putting it back on time?
If by timing you mean that you aren't sure that you have the belt on the cam/crank assemblies properly, now is a bad time to mention it. This is an interference engine. Proper alignment of the crank/cam with the timing belt is critical and must be exact or serious internal engine damage will result. Even turning the engine too far without the belt properly aligned can damage pistons and valves. At this point if you didn't get it right, the damage is probably already done. For a quick check, disable the fuel pump, pull the spark plugs and perform a compression check. If it doesn't pass, take it all apart and assess the damage and repair as necessary.
Nov 25, 2015 | TBK Timing Belt Kit Hyundai Accent 1 6l...
How do you reset belkin router?
Using a opened paper clip there should be a little hole to put in the papclip and depress a little switch. If you can find this then unplugged the power, push in the button hold while reconnecting the power. Whatch the lights and they will flash and then go off and look like nornal.
Nov 12, 2014 | Belkin Components Belkin F9K1102 N600 DB...
How to find timing when installing timing belt to mazda protege?
Personally, I use a paint stick to mark the original belt location. Then I take the belt off and transfer the marks to the new belt. Be sure to put a new water pump in and also a new spring on the tensioner.
If you already took the beloff, then there are actually timing marks. I forget where the mark on the crank is, but it should be slightly obvious. The mark on the gear lines up with a mark on the oil pump. The camshaft gears each have 2 marks. On the front you use the one with the 'e' and the 'I' on the back. The notches have to point at eachother parallel to the cylinder head.
Good luck...
Nov 10, 2014 | Gates 1999 Mazda Protege Timing Belt Kit...
84 pontiac T1000 timing belt replacement
Go to autozone dot com and make a free account, put in the vehilce info and look for the free guides, if they are not online, go to a store and see if they have CHILTONS or HAYNES manuals on it.
Oct 01, 2013 | Victor 1984 Pontiac T1000 Engine Timing...
Can i put my jordan sc 2 in the washer
Yes, of course you can wash your jordan Sc 2 without any problem. Nowadays branded shoes are coming with water proof models,so no need to worry about that.
Apr 15, 2013 | Nike Jordan SC-2 Basketball Shoe Mens...
What can I do with my old running shoes?
You can donate them; Nike Reuse-A-Shoe program (www.nikereuseashoe.com) accepts donations of all athletic shoes that don't contain metal. The shoes are converted into athletic surfaces (running tracks, soccer fields, basketball courts) that are sent to underserved communities around the world. And One World Running (oneworld)
running.com; previously Shoes for Africa) will send your new or gently used shoes to athletes and children in Africa, Mexico, and South and Central America.
Jan 14, 2013 | Running
How long do running shoes last?
Running shoes last roughly between 300-500 miles or between 4-6 months. These are rough estimates as there are several factors that contribute to the breakdown of your shoe, like how often you are running, what surface you are running on, and other factors like heat and weight.
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
Jan 13, 2013 | Running
Running Logo
1,073 people viewed this question
Top Running Experts
Are you a Running Expert? Answer questions, earn points and help others
