Question about Whirlpool GBD307PDS Electric Double Oven
My oven wont work after cleaning with oven pride cleaner
I have cleaned my oven with oven pride cleaner and when i turn it on it trips the switch at the mains box.
Sounds to me like a short. Thats electrical. Now the troubleshooting. I would assume liquid got somewhere and is causing a ground loop somewhere. Thankfully your elecreical system is working as designed. Need to find that short. Possibly one of your element(s) or element connection I think is the culprit. I dont know how handy you are with electrical meters, but i would start at the elements. BE CAREFUL!!! Your messing with 220v. Nasty stuff. Me personally, I would disconnect one element at a time to find which one it is and handle it from there.
Posted on Jan 19, 2013
catriver
  • 878 Answers
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
wbwill
  • 68 Answers
SOURCE: After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Posted on Nov 13, 2008
jcarlton214
  • 105 Answers
SOURCE: Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
Posted on May 28, 2009
barkencoa
  • 3463 Answers
SOURCE: oven keeps tripping mains
If it is a electric oven, then the chances are it is the oven element that is causing the problem.
What is probably happening is that as the element gets hotter, the insulation resistance is breaking down, and causing the trip to operate
Hope this helps.
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: Turned oven on to "clean" cycle now the oven wont
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
No power, door locked
there are 2 thermal switches within the component area in front of the fan of the oven, they open and close like a switch at certain temps,if one of these go bad (stays open after oven clean cycle)and oven cools then it wont let power back to the unlock motor,you can access these switches and bypass them to test them,if lock works then merely replace that particular switch
Feb 04, 2013 | GE Ovens
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
Need directions for oven cleaning
Use oven pride bags with solution for shelves, shelf brackets, inner door glass. For the remainder if the oven use oven cleaner foam spray on an leave for an hour, then plenty of elbow grease for scrubbing up with a wooden scaper
Jul 15, 2011 | Ovens
All I want o know is how to clean it. I think it's a basic question that should be on line with out having to type a thesis to you. I have a day where I can clean it Now I have to wait for your...
Instructions Things You'll Need:
  • Oven Cleaner
  • Soft Rags
  • Sponges
  • Oven Cleaner
  • Sponges
    Self Cleaning
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  4. Fast Cleaning
  5. Remove oven racks and place them in soapy water to soak.
  6. Preheat oven to 200 degrees.
  7. Turn the oven off and spray the inside with oven cleaner.
  8. Allow to sit for 10 minutes.
  9. Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. Dry with a soft cloth.
Feb 02, 2011 | Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
    Here are some solution on how to unlock the door of your oven ans do self cleaning below.
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
    hope this helps you out please rate this solution it helps get better results for our customers like you
    Self Cleaning
  • Fast Cleaning
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    Gas oven - electric igniter - trips electric
    you have cleaner inside the glow coil marrets and it is probably causing a short circuit and tripping breaker
    Feb 06, 2010 | Ovens
    Neff U1421 main oven trips the circuit breaker.
    It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
    Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
    Whirlpool GBD307PDS Electric Double Oven Logo
    115 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
