Lg wd-1438rd wont turn on
I have a LG WD-1438RD washer dryer combo. It was working fine, but I had to move it to fix the hose (it was leaking). When I moved it, I forgot to turn it off at the mains. Now it doesn't turn on at all. When I plug it in, flick the switch, the machine makes a beep. i then press the power button. nothing happens. i hold down the power button. nothing happens. i've tried pressing and holding all the buttons, but still nothing happens. What do you think the problem is? How can I fix it? Thanks for your help!
  • 1294 Answers
SOURCE: need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
  • 489 Answers
SOURCE: washer/dryer has stop
There is no reset button but it could be that a wire has come loose from all that thumping.  Check the connectors to the control board and to the display board to make sure that they're connected properly.
Posted on Apr 28, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
  • 7 Answers
SOURCE: LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Posted on Jan 22, 2009
  • 9 Answers
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
Posted on Feb 14, 2009
Start/pause button on lg wd-1438rd washer/dryer flashing and wash cycle will not start
try pushing and holding for 5 seconds.
rinse+ and pre wash buttons at same time.
that takes off child lock.
Nov 06, 2016 | LG Washing Machines
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
Washing machine wd 1438rd..water keeps draining while washing..
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 21, 2011 | LG Washing Machines
My LG Front Loder/ Dryer WD-1438RD is very noisy on spin dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 03, 2011 | Dryers
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
LG WD-1438RD washer dryer combo won't turn on
Okay well i had the same problem with my LG WD-1438RD so i took it a part it was a loose wire in the display module easy fixed. I guess from banging the door closed and hitting the buttons to hard made it come loose. To fix it all you need is a phillips head take the two screws out of the back up the top then slide the lid forward. then remove the powder tray thing unscrew the 2 screws behind it push the clips out of the way just be careful not to break em. re connect the wires! job done =) i put glue and electrical tape on the wires and plug so it shouldnt happen again..... I hope i helped you good luck
Jun 05, 2009 | LG WM2077CW Laundry XL Front Load...
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
