Question about LG WM2077CW Laundry XL Front Load Stackable Washer
Lg wd-1438rd wont turn on
I have a LG WD-1438RD washer dryer combo. It was working fine, but I had to move it to fix the hose (it was leaking). When I moved it, I forgot to turn it off at the mains. Now it doesn't turn on at all. When I plug it in, flick the switch, the machine makes a beep. i then press the power button. nothing happens. i hold down the power button. nothing happens. i've tried pressing and holding all the buttons, but still nothing happens. What do you think the problem is? How can I fix it? Thanks for your help!
    Top Expert:
  • 867 Answers
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
Posted on May 15, 2017
  • 10 Answers
SOURCE: lg wd-80130f
sounds like whoever changed the pump has made a hash of the wiring, get them back to it.
Posted on Feb 04, 2008
  • 489 Answers
SOURCE: washer/dryer has stop
There is no reset button but it could be that a wire has come loose from all that thumping.  Check the connectors to the control board and to the display board to make sure that they're connected properly.
Posted on Apr 28, 2008
SOURCE: LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
turned out to be the control board and the transformer - an expensive fix!
Posted on May 27, 2008
  • 7 Answers
SOURCE: LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Posted on Jan 22, 2009
  • 300 Answers
SOURCE: It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Posted on Mar 07, 2009
Start/pause button on lg wd-1438rd washer/dryer flashing and wash cycle will not start
try pushing and holding for 5 seconds.
rinse+ and pre wash buttons at same time.
that takes off child lock.
Nov 06, 2016 | LG Washing Machines
Washing machine wd 1438rd..water keeps draining while washing..
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 21, 2011 | LG Washing Machines
My LG Front Loder/ Dryer WD-1438RD is very noisy on spin dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 03, 2011 | Dryers
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
My Lg WD-3274RHD after a load is complete It fills with water again? If left ovder night water will run out the door.
I have same problem with my washer/dryer combo.It took me quite some time to figure out what is going on.Did all electrical checks ,everything was fine and worst thing it was intermittent thing ,it would do it 8 out of 10 times. Found cold water inlet valve assembly to be faulty (mechanical problem with middle valve) . Second time in 6 years ,other than that I'm very happy with that combo.Problem now is to get new valve, because it is not available anymore from LG, so I'm digging through internet to see if anybody has it somewhere. Good luck
May 06, 2010 | LG WD-3274RHD Front Load Washer / Dryer
LG WD-1438RD washer dryer combo won't turn on
Okay well i had the same problem with my LG WD-1438RD so i took it a part it was a loose wire in the display module easy fixed. I guess from banging the door closed and hitting the buttons to hard made it come loose. To fix it all you need is a phillips head take the two screws out of the back up the top then slide the lid forward. then remove the powder tray thing unscrew the 2 screws behind it push the clips out of the way just be careful not to break em. re connect the wires! job done =) i put glue and electrical tape on the wires and plug so it shouldnt happen again..... I hope i helped you good luck
Jun 05, 2009 | LG WM2077CW Laundry XL Front Load...
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
54 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
