Question about youtube.com
It is completely black around the bottom left side and the other part is so dark you can hardly see it
  • youtube.com Master
  • 1,824 Answers
Can you please either post a screenshot here or to tomas.and.jueros@outlook.com
Posted on Jan 13, 2013
Tv is black but on
the main board probably has a crack in solder joint some where.
Feb 17, 2016 | Samsung LN40A450 LCD TV
Lcd bulb replacement
If it is left side/ right side problem it can be the tcon board or the connection to tcon board.
Jan 17, 2014 | Insignia Televison & Video
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Left side of screen is dark
When you say the screen is dark, do you mean that the picture is still faintly visible or is the left side black with a sharp edge between the black and the visible picture?
If the screen is dark with a faintly visible picture then you have a faulty backlight. This could be due to the inverter board, which can be repaired or replaced, or it could be the CCFL tube which is a bit harder to replace.
If the left side is completely black with a sharp edge then the LCD itself is faulty and may require replacing.
In any case, any of the problems listed above should only be repaired by a competant electronics engineer.
Feb 14, 2011 | Philips Televison & Video
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
37in Proton
Those are the symptoms when the power supply is giving up.
Unfortunately there are not many replacement service parts around to swap the power supply assembly, but It will need to be fix to the component level instead.
I service these power supplies.
Let me know if you need more assistance.
May 02, 2008 | Protron PLTV-37 37 in. LCD Television
Lcd dark
Use an eyeglass screwdriver to remove the back half of the case. (6 screws, 2 screws each on sides and bottom) When you remove it, the ribbon cable for its buttons comes out just by pulling. You now see the LCD (which is fine), its cable connection (lower right), its power connection (two wires on right). Either these wires have come unsoldered (easy to fix without microsoldering capability) or some part of the power supply for the LCD backlight is bad (very hard to fix, you probably need a new motherboard). When you put the case back on, first you have to plug in the ribbon cable - first open the tiny black plug lock out and around to the left, put the cable all the way in, then lock the black part back right and in. Screw the case back on and you're fine.
Jan 14, 2007 | Casio Exilim EX-Z750 Digital Camera
youtube.com Logo
Top youtube.com Computers & Internet Experts
Mike
Jerry King
Jerry King
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
