Question about Tascam US-144 Sound Card
I want to record midi from external keyboard. A red midi in light goes on, but I can't see or hear any data in my computer programme when I try to record.
I have 144MKII model that came with cubase le5. I'm using windows 7. Please help! A red midi in light goes on, (Should it be red??) but I can't see or hear any data in my computer programme when I try to record. I hear nothing in my headphones at all. When I click stop to end the recording I see that nothing is recorded and I assume nothing is being sent form the tascam to the computer!
SOURCE: hellp!
im not familiar with cubase but if its anything like logic and reason, you should check the midi options maybe in preferences of the cubase programm and make sure that the appropriate soundcard is selected, so in this case the us-144.
and sometimes it could be one of those stupid midi glitches, and so you have to restart your computer.
maybe the best opt is to get a better soundcard.
im this close to throwing my tascam under a bulldozer..
Posted on Feb 26, 2008
  • 34 Answers
SOURCE: i hear background whitenoise/static
You need a better quality connection. Make sure that all of the wires run a straight path without unneeded or unnatural twists or ties. You also need to use the best cables for your situation. This means that you should use the right length and gauge recommended for your devices. If none of this works, you can always get an electronic loop-isolator (sweetwater, radioshack) which is essentially an enexpensive feedback eliminator and does the same thing as a grounded outlet, elimintating all of the extra "electric noise" which is not needed. Make sure that your devices are all plugged into grounded outlets as well. A surge protector with grounded slots will not always work, especially if it is not inserted into a three-prong outlet. Another thing is to make sure that no extra current is running through your devices. Because, in addition to the "noise" you are also damaging your equipment more from such "noise." In fact, depending on how long you have used your equipment, you may have already done some damage.
Posted on Mar 22, 2008
  • 3 Answers
SOURCE: No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Posted on Oct 19, 2008
SOURCE: recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Posted on Nov 21, 2009
  • 8 Answers
SOURCE: using a Tascam US 122 with Cubase SX, when
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Posted on Mar 01, 2011
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Using Keyboard for Mbox 1
You have to select the port in Pro Tools, but the computer has to recognise the MIDI port first.Does P.T. see that you have a MIDI port installed? Did you select an instrument plug in and map the keyboard as the controller for the plug in? You may need to use a utility like MIDI Yoke or MIDIOX to map the port if you are using Windows. You also have to have the drivers installed so that Windows recognises it as a MIDI port. If it is on a Mac you may have to use the Audio/Midi setup up utility to add the midi port.
Best of luck, Let me know if I can help further.
Dec 25, 2008 | Digidesign Mbox External Sound System
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Open Questions:
See all Tascam US-144 Sound Card Questions
Tascam US-144 Sound Card Logo
Top Tascam Computers & Internet Experts
Ben Armstrong
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
