Question about Cadence Weslo 620/630 Treadmill Walking Belt
Weslo cadence 630 it runs for about three minute then cuts out
It stops after three to five minutes
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
SOURCE: can not find my manual for my weslo cadence ts5
try this site and type in model and type...manual will be a PDF booklet
http://www.iconservice.com/CustomerService/manuals.do?dr=WL
Posted on Jan 10, 2010
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
maxtreadmill
  • 832 Answers
SOURCE: walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Posted on Mar 02, 2010
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Posted on Jun 20, 2010
Hello i have a weslo cadence 260 treadmill,it runs for about 1 minute then stops,the motor stops too,i have to keep tuning it off and on for it to work again,whats the problem with it,would be great if you...
It sounds like you have a worn deck and (or) belt. If the machine runs just fine without being on it but stops when someone is on it, then it sounds like a worn belt/deck.
The friction under the belt is so great that it overworks the motor to the point where it shuts itself down. The surface needs to be slick and smooth for the motor to work the least amount.
You could try to put some silicone under the walking belt and see if it helps. It really depends on how many miles are on it.
Feb 24, 2011 | Cadence Weslo 620/630 Treadmill Walking...
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Shuts down after running a few minutes
hi when you mean shuts down it that the power or just the belt, if everything including the power turns off then check the trip switch on the front of your treadmill, and if you are using an extention wire on a roll, please unroll the whole thing that can cause a short. and if you can smell any burning thats a sign that the motor and belt are either too tight and on they way out.
Nov 12, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Need a new saftey key where do i get one
Call Icon Fitness @ 1-800-999-3756 Description: KEY/CLIP Part# 155398 Price $2.38
Jul 31, 2010 | Cadence Weslo 620/630 Treadmill Walking...
After walking about 15 seconds the belt slows way down and stops completely.
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Apr 26, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Got a weslo cadence m5. on it for 15 minutes stopped completely. got electric working again by pressing trip switch on bottom. when i press go it try's to jolt a little but thats it. had a look underneath...
You know I have exactly the same problem..with mine jolt and nothing more. trieed it for 15 minutes then just stopped! have you found a solution yet!
Sep 23, 2009 | Cadence Exercise & Fitness
Mar 22, 2009 | Cadence Exercise & Fitness
Cadence Weslo  620/630 Treadmill Walking Belt  Logo
29 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
