The sky screen has gone really small on the tv screen, how can I get it back go normal? It was fine this morning then I think my sister sat on the remote
    New Friend:
Go to menu, video set up and change it to fit instead of zoom
Posted on Jan 13, 2013
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
SOURCE: tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
bobint17
  • 270 Answers
SOURCE: my hitachi 960 tv has a green screen
you should take the remote,press the menu key.select the screen settings.in this you can set your screen.
Posted on Jan 20, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
dave1645
  • 834 Answers
SOURCE: somehow i must of pressed something on either my
go into the menu and picture setting and select what you would like other then zoom
Posted on Dec 02, 2009
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
My Samsung TV picture has gone really small and into the top right hand corner - is this easily fixed?
This is a simple remote problem. It is the picture option. Just make sure your remote is on TV and press help. It should turn that screen on and off
Mar 16, 2011 | Samsung LN-S4051D 40 in. LCD Television
My LG 37LG50 screen turned all green and stays that way.
Hi, Is the problem on everything?
eg. Cable - Sky - DVD - Normal Terestial TV.
I had a similar problem when I was viewing Sky but found out it was only affecting sky. Turned it of and left it for 1/2 hour then plugged it back in.then all was fine ( something to do with humidity).I'm not saying this is the problem, but check it out.
If you stiill need more help - please ask.
Tony
Jun 06, 2010 | LG 32LX1D 32 in. LCD Television
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Video or Sound
Hello Mabsab:
The repairs may cost starting at $ 75.00 to $100.00 for the estimate and basic trouble shooting the final cost of the repair may be about $200 to $400.00 dllars depending on the price of the part and the labor that is charged.
Aug 17, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Fuzzy picture
You need to test it using a DVD player or Blueray player.
If you still get the problem, call that tv service company back and tell them the problem is with the TV.
Get them to test it while you're watching so you can point out the fault to them.
If it works great with a DVD player, then the fault is likely with your Sky box. Here you would really need a second portable TV to test your sky box with. This would confirm the fault is not in the TV.
May 06, 2008 | Televison & Video
Green circle on the screen when I turn off TV
there is something really something wrong with your tv.try to reheat the main board.
Oct 30, 2007 | Sony KV-27FS13 27" TV
Televison & Video Logo
Top Televison & Video Experts
