Question about Gateway ZX493131e Notebook
Computer fan running loud
Dust on the fan
  • Gateway Master
  • 7,627 Answers
Clean fan and vents, A dusty computer will overheat and damage the components.
Posted on Jan 13, 2013
Acre z5700 turns off
A really loud fan can be one of two things - neither is very good to have for very long. Most newer motherboards support multi-speed fan operation based on CPU temperature. This keeps fan noise at a minimum because the fan only has to run fast (and loud) if the CPU exceeds a specific threshold temperature. The loud noise could also be from a fan that is starting to fail and is binding, thus running slower than normal. Either of these conditions is indicative of a problem that kills PCs - heat. Open the case and carefully examine the heat sink fins and the fan on the CPU. If they are caked with dust (especially the fins), then the CPU will likely overheat and shut down. Get some canned air designed for cleaning electronic components and blow the dust from the fins and the fan. Restart your system a see if the fan runs slower and quieter now, Machines that are in dusty environments, around smokers, or placed on the floor are especially prone to dirt buildup. Periodic cleaning with the canned air is the way to keep your PC happy and healthy.
Dec 10, 2013 | Acer Computers & Internet
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Fan runs loud
Clean the dust from around the fan, vents and inside the computer with a can of compressed air. The most important thing is that they run. Both fans, the one inside the power supply and the one that sits on the motherboard.
The fan seems to be running hard and loud. i have cleaned the system and it's running quieter since then. is that normal for the system to do?
I'm assuming that when you say you cleaned the system that you mean you removed programs, old files, viruses, etc.
If your computer is set to change fan speed based on how hot the processor or video card gets, which it probably is, then more programs and stuff running on the computer would cause your hardware to work harder, get hotter, and need more ventilation. Thus faster fan speed.
However, I believe what really happened is that dust collected on the fan(s), causing them to make some new noises and then the dust fell off because it was so heavy or it got sucked through the fan and out of the way finally. Which means it was a coincidence.
Now if you meant that you literally cleaned the computer (opened it up and blew all the "dust bunnys" out) then yeah it makes perfect sense that it would be come quiter.
By the way, if you have not opened the computer case and cleaned out all of the dust, you really really should.
Disconnect the computer from the outlet, open up the case, and using a can of compressed air (about $5) blow out all of the dust, hair, and dirt to make sure your hardware stays in good condition.
Dec 19, 2010 | HP Pavilion a805n (PS519AA) PC Desktop
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Reving,loud
Restart your computer -- there may be some "run-away" program on your computer that is working the CPU to its maximum.
Also, there are some heat-sensors inside your computer, i.e., the hotter that the inside of your computer is, the faster that the fans will run.
Check that the fan on top of the CPU is still working -- if not, your CPU will generate a *LOT* of heat.
Also, turn the computer off, and take a can of compressed air, and give your computer a "blow-job" to remove all the dust from inside your computer -- dust makes a great insulation, thus making your computer run "hotter" (and making the fans work harder/louder).
May 29, 2010 | Dell XPS 200 PC Desktop
Latitude e6500 runs hot how do i boost the fan
You may need to clean the fan and heatsink of dust. See the dust restricts the cool air from reaching the heatsink and this in turn causes your fan to spin faster. The computer's BIOS is programmed to increase CPU fan speed as CPU tempreature increases. If your fan is very loud, then it is running at the maximum speed possible. A clean heatsink will decrease the Processor's temperature.
Installing additional fans in your computer's chassis is an effective way of bringing the temperatures down. Install the biggest fans that your chassis supports. 120mm fans are better than 80mm fans as they can spin at slower speeds to provide the same airflow of a smaller fan. Therefore giving you a quiet computer.
Use a program called Speed Fan to ensure that your fans are indeed running at the desirable level of 100%
Take care!
damnor01
May 12, 2010 | Dell (6F858) Cooling Fan
Noisy fan
Clean the computer from dust, use canned air to blow the dust out, as the airflow increases the fan wont have to run so loud.
if the fan is really loud, it needs to be replaced.
Aug 11, 2008 | Computers & Internet
Computer fan is loud & computer running slow
There are a number of reasons might be affecting, some are dangerous while others not that serious. Learn why and how you can speed it up easily from: http://www.whyismypcsoslow.net/ hope this helps take your stress out!
Feb 09, 2008 | Dell Inspiron 9300 Notebook
Loud noises coming from power supply fan?
it might be the fan of your cpu has dust.and making it the fan hard to spindle.if you can dismantle your cpu fan or the fan in your power supply.just clean it with the paint brush.or do it with vaccum cleaner.if you have air compressor the would be better.just blow out the dust.then if you can do it also just putting oil or grease inside the fan at the core.the one that has magnet.it will smoothen the spindling.ok good luck
Dec 03, 2007 | HP Pavilion 505n (DC470A#ABA) PC Desktop
Gateway ZX493131e Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
