Question about Philips Magnavox 27MS343S 27" TV
Turn on tv pic turns gray and black lines then turns off
I turn my tv on and gray and black horizontal lines for about five seconds and then the tv turns off. it is a phillips magnavox tv model # TS2774C101 manufactured in 1999 3219W181B. I would like to know what part it might be because it is such a great picture and tv. i do not have the $ to lay out for a new tv so it would be great if u could help me.
  • 373 Answers
I am happy to assist you. If I am not mistaked about your model, I know of a fix for some models and that for sure. According to your description, I know of this descripition and if it fits the fix I know about then I am sure to tell you the problem.
You have to take the back off the set (UNPLUG TV) and look on the neck of the picture tube on the circuit board there is a resistor (do research on what a resistor is on the net) that opens up and it is a 10 ohm resistor and the color code is brown black black. It is about half inch long with wire coming out both sided sitting straight up position from the circuit board. Can be measured with an ohm meter. You can get 5 of them for a dollar at Radio Shack and it must be soldered in after taking the old one out being careful not to break the printed circuit.
Your symptom should be also getting brighter and brighter and then shutting off.
Hope this helps
Posted on Jan 23, 2009
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
Nov 28, 2015 | Proscan 32LB30QD 32 in. LCD TV
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
I have a sharp tv 21" if i turn it on or change channel,pink display will appear with red horizontal lines about half inch intervals dn a few seconds it will turn normal but the red horizontal lines remain...
my sharp tv was like that to but our tv color was blue with also gray horizontal lines i did cheack all d caps resis... etc dont know what to do LoL.
Feb 07, 2010 | Sharp Televison & Video
When first turns on, large black horizontal lines make picture unwatchable.
from possltd@hotmail.com the problem is the 3 thin ribbon wires that go to the lcd have become lose,or something else open top cover 6 screws 4 on the sides 2 on top must remove dark gray plastic piece have pic if needed Oct 4th 09
May 30, 2009 | Sony VPL VW10HT Multimedia Projector
Horizontal lines
vertical line on my TV
Nov 21, 2007 | Sanyo DS32920 32" TV
Won't stay on
The quick horizontal line through the center of the screen usually denotes a failure in the vertical output circuit, and that would keep the set from staying on. You would have to take it to a repair shop for repair.
Dec 09, 2006 | Mitsubishi CS-31305 TV
Philips Magnavox 27MS343S 27" TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
