New firmware for fixing the Hd issue in FUJI av 100 available . ver 1.02
[not available in website] mail me :[email protected]
ii can send the new firmware
I'm unable to assume the exact problem with your mp3 player as you've bluntly said that the device is not working. Try the following steps and that should work. If not let me know:
STEP 2 - Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware - Sansa Fuze firmware update - Sansa View firmware update - Sansa e200 series firmware update - Sansa c200 series firmware update
Hi, 1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC 4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on). 5. Try other modes as well. Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device ii. Right click on My Computer and select Manage iii. Select Device Manager iv. At the right hand side look out for Portable devices and click on the + symbol to display your device v. Right Click on the device and select Update Drivers vi. Select 'No, not at this time' and click Next vii. Select 'Install from a list or specific location' and then click Next viii. Select 'Don't search, I'll choose the driver to install' and then click Next ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
This doesn't require downloading anything, installing anything, or
holding your mouth in a certain way.
1) Plug the drive into power and into your Vista PC's USB port. 2)
When the 'Found New Hardware' wizard pops up, click the
recommended option. When it says it can't find the drivers, select 'Show me other options', and then Browse your computer for drivers. Choose the C:\ drive, and click next.**
**The
key here is that Windows Vista comes pre-installed with the drivers for
the Maxtor external hard drives. So they're on your PC, even if the Wizard tells you they're not.
4) Wait a few minutes, and
yo will see a window that
reads, "The software for this device has been successfully installed,"
and now it will appear as a drive letter under 'Computer'.
I have the same problem, but havent found ay way around it.......i am also getteing pritty desperate here................the old one had this problem...cant fint it in device mannager, dos or anywhere else....no matter which computer i try, xp, vista no deifference...
