Question about Frigidaire Refrigerators
Frigidaire rle1405 larder fridge not cooling - Frigidaire Refrigerators
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
tborn6
  • 700 Answers
SOURCE: larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Posted on Jan 13, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Frigidaire Fridge is not very cold in side
Try replacing the breaker switcth/capacitor assembly. Is right on the compressor.
Posted on Jun 28, 2009
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
  • 228 Answers
SOURCE: Bosch larder fridge KSR stopped cooling - has been
if he means temp sensor he is correct as they are foamed into the liner in manufacture you would destroy the liner to reach it however there are repair kits available for some models which bypass faulty sensor and allow it to run on ambient sensor you will need to check with bosch tech dept to verify this.
Posted on Nov 10, 2009
How do I remove the light bulb cover on my Frigidaire Larder Elite RLE 1099A fridge
Look for a screw that holds the lens in place. If nada then small tabs on side of lens click into the wall. Squeeze the sides of the lens and that should free up the lens.
Jun 22, 2016 | Frigidaire Refrigerators
My larder fridge sr5045 frosts at top but dosent get cold enough
low on freon, freezing up no cooling, probably just has enough in it to cool your fridge.....
Aug 02, 2013 | Refrigerators
Larder fridge light on but not getting cold
Check condenser clean and warm. If too hot, may be fan not running, if too cool, compressor not pumping or short of gas
Aug 07, 2012 | Frigidaire Refrigerators
Hi, I have a frigadaire rle1405 larder fridge that does not get cold,could you please tell me where the defrost timer is on this model. Thank you.
Many of the frigidaire units had problems with the defrost termination thermostat located in the freezer compartment. (I have repaired many). It is around 12 dollars
It is clipped to a tube located in behind the freezer back panel. take out the
plastic vent and motor, unplug the motor (very carefully to prevent pulling out the
leads) the defrost termination thermostat has two leads and is clipped onto a
tube. The replacement will have heat shrink and wire nuts, but I often use
**** splices under heat shrink tubing to ensure no moisture gets into the connections and a dab of silicone at the ends of the heat shrink. Make sure the "colder" knob
is set in the middle on the vent stack as this will cause problems if set to "colder".
I have only seen one defective defrost timer (incorrectly assembled) which caused the
gear to stick in one position. You can manually rotate the timer to check operation with
a screwdriver in the access hole on the bottom of the temp control panel. (oddly the new timers are of a different make if it has failed). Unplug unit before servicing.
May 29, 2011 | Frigidaire Refrigerators
Jun 28, 2009 | Refrigerators
Back wall of larder freezer icing up - fridgeidare RL 6003 B
located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Try first a complete defrost, leaving the unit unplugged overnight, if this does not fix the problem, then there is a fault.
Jan 20, 2009 | Frigidaire FRS23F4C Side by Side...
Larder section of fridge not functioning
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sep 23, 2008 | Liebherr Refrigerators
I have a larder fridge that seems to collect too much water in the tray at the back, it seems to be temperamental with cooling. It only works part time. How affected are they by not being completely level?...
this water should be evaporated by the motor heat.however, i have found with larger larder fridges of several makes that too much water is formed for it all to go.
worth while checking the door seals as well as if seal is leaking, more ice forms on the evaporator and hence more water
Aug 31, 2008 | Frigidaire Refrigerators
Refrigerators Logo
102 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
