Question about Standard Power Center for Aqualink Rs
I have an Aqualink RS power center that is humming. It did not seem to hum before. Is this normal.
  • 372 Answers
I have worked on RS systems for many years and have not yet run across one that hums. I would think that it may be coming from one of the relays or a light dimmer, if you have one installed. Unless you are well comfortable working with high voltage, call out a tech to isolate the source and determine if any repair is necessary. Sorry I couldn't be of more help.
Posted on Jan 13, 2013
I have a Jandy Aqualink Power Center that is humming. I have not heard it hum befor. Is this normal.
check to see if you have proper voltage coming in then test transformer to see if 24 volts if so start unplugging the auxs 1 at a time until it goes away sounds like a relay is stuck if not give me more info
Jan 13, 2013 | Standard Power Center for Aqualink Rs
Code 170 in aqualink rs
manual says error 170 front board sevice indicated and usually caused by low ac voltage from backboard check backboard and transformer voltages if voltages are good a shorted cell will also cause this
Jan 29, 2012 | Standard Power Center for Aqualink Rs
My Jandy Aqualink, all the buttons are lite up and the display says 6700 REV C
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
May 21, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy hand held just says wait wont connect. I tried reset and fliped circuit breaker
May 13, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink rs8.Pool and spa lights wont come on. (programming?)
If it's both lights and they are on seperate switches I would start by checking the GFCI and be sure it is not tripped and if it is you would need to find out why. Then check power in and out of the light module in your power center. If you can set the power center to service and turn the lights on manuley from there then it is programming but most of the time it will be something in the lights or their circut.
Mar 06, 2010 | Jandy AQUALINK RS TELELINK KIT
My aqualink power center and indoor control has no power, but the aquarite chlorine system is still lit up. Is there a fuse or a board the can be replaced?
The chlorine controller is wired seperately from the aqualink, you need to find a different circuit breaker/fuse to power it down or trace the cord and unplug them.
Sep 15, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink display reads "waiting"
System locked up. Handheld is frozen at WAITING screen means Microprocessor is locked.
Here is what you do:
1. Turn off power to the system (control box)
2. Disconnect battery at the Power Center (9volt battery in control box/cross tip screwdriver required)
3. Turn on power
4. Reconnect the battery
5. Reset time and date on PDA.
6. Thank me.... BadWally sends
Aug 20, 2009 | Jandy AQUALINK RS TELELINK KIT
I have a jandy aqualink RS PDA. It will not
System locked up. Handheld is frozen at WAITING screen. Microprocessor is locked.
1. Turn off power to the system.
2. Disconnect battery at the Power Center and turn on power.
3. Reconnect the battery and reset time and date.
4. Thank me.... You are welcome... BadWally sends.
Jul 03, 2009 | Jandy AQUALINK RS TELELINK KIT
Noisy transformer
Normally, power transformers don't hum loudly unless there is a problem in power supply circuit. If all seems normally operational, the problem may be simply anchor screws that hold transformer to frame may be loose. Try tightening them
Apr 29, 2008 | Parasound HCA-855A 5-Channel Amplifier
Standard Power Center for Aqualink Rs Logo
56 people viewed this question
Top Standard Pool & Spa Experts
richie46
Ian Kime
Ian Kime
Bill Jordan
Are you a Standard Pool and Spa Expert? Answer questions, earn points and help others
