Question about Toshiba Computers & Internet
Broken Laptop Screen: Toshiba Satellite c670-165
Does anyone know how to change the screen on this product, the bottom screws are obscured by the laptop case itself?
  • Toshiba Master
  • 5,660 Answers
As in this model?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/remove-replace-screen.htm
The Display Assembly is laid back to a point, that you can access the two bottom screws. Isn't a direct 90 degree position with the screwdriver. More like 60 degrees.
No?
Then the Top Cover (Palm Rest Cover) has to be removed, in order to access.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/remove-replace-lcd-screen-inverter-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Don't forget to remove ALL power. AC adapter and Battery.
Regards,
joecoolvette
Posted on Jan 13, 2013
Joed911
  • 4338 Answers
SOURCE: TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
SOURCE: Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Posted on Mar 15, 2009
frankzjm
  • 191 Answers
SOURCE: A305-S6858 Laptop screen replacement
please reference follow steps to disassemble LCD screen
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
be careful all small cable like KB top cover LCD cable and inverter cable.
hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
Posted on May 21, 2009
  • 1087 Answers
SOURCE: How to Remove the bezel from a sony vaio
http://www.fonerbooks.com/laptop_8.htm
Posted on Mar 29, 2010
  • 476 Answers
SOURCE: my screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
Posted on Apr 06, 2010
ANYONE KNOW WHY MY TOSHIBA SATELLITE L645 BECOME BLACK SCREEN BUT THE PROGRAM STILL RUNNING ?
you probably don't need a new screen it's probably your screen inverter that's going. It's just a small strip at the bottom of the screen wjth a little circuit board. If you google screen inverter and the make and model of your laptop you'll see what I mean.
Nov 27, 2012 | Toshiba Satellite L645-s4102 Notebook
Trying to remove the lid from a toshiba c660
The lid has to come off. Make sure you remove the strip that is right above the keyboard so that you can get to the screws that hold the lcd in place. Also remove the screws on the bottom of the laptop that are right under the lcd screen. Sometimes there are screws on the back side of the lcd screen that have to be removed.
Apr 26, 2012 | Toshiba satellite c660
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
I am in need of a repair manual for a Toshiba Satellite L455-S5975 laptop in order to replace the LCD screen. I have searched everywhere, but no luck. Does anyone have a source? Thank you.
Not sure if you will find one... Process on toshibas is:
Pop top cover (sometimes also secured with a few screws on side or bottom of laptop) near monitor base above keyboard to access LCD cable and mount screws
Unplug cable and remove monitor mounting screws (Under plate, on back where cables plugin, and sometimes on bottom)
Take monitor (on flat surface) and remove screw covers with needle so you can put them back on later.
Remove all screws
Use plastic credit card and run around outside lip of screen case until removed
Remove LCD mounting screws
Remove LCD and inverter
Remove LCD brackets and inverter from panel
Replace panel and start working backwords.
Mar 31, 2011 | Toshiba SATELLITE L455-SP5016M LAPTOP LCD...
Hi I cracked the screen on my toshiba Satellitle L670-10N and have ordered and received a replacement. However, when trying to remove the broken screen, I cannot unscrew the screw on the bottom of the...
The screen portion of the laptop should be removed from the keyboard portion. There should be screws in the back of the laptop, or under a removable plastic piece directly about the keyboard. This will have to come apart anyway, because you have to remove the video cable from the mother board to replae the screen anyway.
Mar 21, 2011 | Toshiba Satellite L670D-ST2N03 Laptop...
Change keypadtoshiba L300 laptop
Try this....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L305-L305D/remove-screen-replace-video-cable-1.htm
The trick is to remove the screws under the battery vecause they hold the bezel into place, once that is done, pry the bezel up and out of the way then remove the screws on the top of the keyboard and lift the keyboard at a 45 degree angle and move it slightly toward the screen to unhook the tabs at the bottom. Unhook the cable socket and move the board.
Sep 25, 2009 | Toshiba Satellite Pro L300 Notebook
My toshiba satellite mother board wont work how do i get this fix
Common problems are loose CD jack, dust on the memory pins, a bad battery. if you are sure the motherboard is bad you can buy one on ebay from a reputable seller and change it yourself (if you feel confident). alot of screws and many delicate cables. Make sure you get the exact model laptop , i usually try to buy the bottom half complete and just install the screen, these guys buy pallets of laptops from bestbuy,etc with broken screens and sell them as tested working with no screen on ebay or other wesites.
good luck
Eric
Jul 30, 2009 | Toshiba Computers & Internet
May 21, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Replacing screen on toshiba sattilite a215-s6816
There are screws that fix the hinges to the base of the laptop, usually two screws per hinge and these are located on the back of the laptop, remove them. Remove the panel on the laptop that is adjacent to the bottom edge of the LCD screen, this may be a single part of the plastic around the keyboard, may have to remove the screws on the bottom of the laptop, carefully unclip the plastic surround around the keyboard.
There will be two connectors attached to the LCD, one for the video signals and the other for the backlight power, near the bottom edge of the LCD screen, detach these before you remove the LCD.
Dec 30, 2008 | Toshiba Satellite PSAFGU-048002 Notebook
Computers & Internet Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
