Question about Homelite Mighty Lite Lawn Trimmer
What is the part number for a choke cover for homelite
It won't start because the choke cover is missing and I need the parts number for it the model is hlt 26cd
    Scholar:
  • 119 Answers
You will have to go to www.homelitetools.eu
you need p/n 5131001732
copy and paste this link to a new browser
http://uk.services.homelitetools.eu/materiel.asp?zzz=1&materiel=HLT26CD&serie=1&DBRequestOnlyOneKEY=HLT26CD%231
hope that helps
regards
Posted on Jan 24, 2013
trippssmengi
  • 76 Answers
SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
did you try fresh gas
Posted on May 31, 2009
#1 Taper
  • 1040 Answers
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
Biggdex35
  • 333 Answers
SOURCE: How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Posted on Jul 12, 2010
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
HHT-2660 Roto choke Cover missing
Contact homelite online or by phone!
Jan 24, 2013 | Garden
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
I had a hard time getting the trimmer to start & when it did start it was difficult to get to keep running. I held the choke between full choke & half choke & it ran for about 20 seconds &...
The pull cord problem probably is not related to the runnability issue of the Homelite trimmer. It most likely needs the carburetor cleaned and a new gasket and diaphragm kit installed to restore it. It may also need a few small adjustments of the Low and High speed mixtures screws. A lot of different things can cause these machines to function poorly...too many to list. By process of elimination and proper diagnosis of each function is the only way to tell...even if it means disassembling the complete engine. M ost times though, the problem you are having is a fuel supply problem. You are forcing the engine to run "rich" when any choke is applied to it at all, as choke cuts out air intake, but not fuel.
The pull cord issue is another animal and can only be fixed by some disassembly. I will give you the instructions on how to do this, but the course of action you take is your own choice. Remove the tube that holds the flex-drive shaft from the front of the motor cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #20 screw. Before you loosen it, ou will have to lock up the engine. Remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-20 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Sep 10, 2011 | Homelite Garden
98 Sportster 883. starts & w/ choke, won't take throttle or choke off w/o stalling. Bike sat for a long time (years). Used Gumout to clean carb b4 pulling tank, cleaning & put fresh fuel -...
No, nothing else to check. You need to completely disassemble the carb and clean it out. When gasoline left in the float bowl evaporated, it left behind the gummy additives that the refinery puts in the gasoline. This mess has clogged the jets and small passageways in the carb. The reason it runs with the "choke" out is that it is not a real "choke" but rather an "enricher circuit". It has it's own air passageway and fuel metering "jet" in the float bowl.
Good Luck
steve
Aug 01, 2011 | 1993 Harley Davidson XLH Sportster 883
Lost OM, starting question - Homelite 10655 chain saw
The compression release should be a metal button that projects from the cylinder head and extends out from the cylinder cover so that it can be depressed before starting. There should be an immediate lessening of compression when pushed. If no such result, the release mechanism should be removed and cleaned, or replaced. Proper starting is to pump the primer button several times to fill the bulb with fuel, then set the choke closed, the ignition on and set the fast idle on the throttle. Pull the engine through several times until it pops, then release the choke part way, and try to start. Don't pull the throttle during this as it will release the fast idle setting. Once the engine fires, the compression release should self-reset for maximum compression. Hope this makes sense and helps!
Apr 21, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I am trying to take off the top half of a homelite 330 chain saw to get at the carb. to get at the ''boot'' How is that done ?
This saw?
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Find your saw, all parts are illustrated,
Jan 27, 2010 | Homelite ZR10926 16 Chain Saw
I have a recoil problem and I think I might have a spacer or washer missing. Spring is OK but tightening screw that holds assemble in place locks recoil action.
You can find an IPL (exploded parts list) here:
Detail is usually sketchy. I found nothing that matched the numbers you posted. Good Luck
Lou
Jan 07, 2010 | Homelite ZR10926 16 Chain Saw
Recoil for a pownerstroke or homelite I may be missing a part and would like to see a parts book.
Detail is usually lacking but it is the only illustration I have found. Good Luck
Lou
Jan 07, 2010 | Homelite Garden
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
53 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
