Question about Welding Tools
Miller Big 40 will not weld and has no current at the A/C outlet
I have a Miller Big 40 welder, serial # HD71116, that was welding perfectly about a month ago. It isn't used often. I tried to weld with it today and it would not weld or run A/C tools from the outlet. The motor runs fine and the welder/generator seems to be running but produces no current. I have a wiring schematic and physical drawing of the welder. What could be the problem and what should I check first? Thanks for any help you can provide.
  • 3 more comments
  • ldmsharp Jan 23, 2009
    Thanks but that does not appear to be the problem because the welder will not supply the stinger with current for welding either.
    I appreciate your input and if you have anyother ideas I would welcome them.
    Thanks!
    Thank you for your help. The welder is DC only with an AC outlet. It is a pipeline welder roughly equivalent to a Lincoln SA-200. I'll let you know what I find after I have tried your suggestions. Again, thanks a lot for your help.
  • danielcpierr Mar 04, 2009
    The welder works but the arc is so week that it only welds on high rang.
  • jbccoe05 Mar 08, 2009
    I have a Big 40 also, serial #HE772374. I was told I need a new armature. Does anyone know where I can get a used one?
  • Anonymous Apr 01, 2014
    wont weld on dc current
    Problem Solver:
  • 7 Answers
Open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Posted on Feb 04, 2009
  • 3 Answers
Check to make sure that the throttle is reving up. I have the same machine and have had the same problem, the short fix I used was bailing wire on the carb. LOL. Turned out to be my idle solenoid.
Posted on Mar 11, 2010
My machine did the same thing. Used it on a Friday, no output on a Saturday. Nothing to do with idle speed, engine runs fine, pull throttle manually as its diesel. Would rectifier cause this in both the AC outlet and the welder output, or should I rule that out?
Posted on May 02, 2015
  • hittman375 May 02, 2015
    The SR1 bridge rectifier might cause this. As I said before, check to make sure the brushes are making good contact and the slip rings are clean. Also check R3 resistor and make sure the slide is making contact on the resistor. If all of that is good then it's time to check the generator windings.
    Problem Solver:
  • 14 Answers
The first place I would look is to check the brushes that ride on the slip rings and make sure that they are making good contact with the slip rings and clean the slip rings with either an armature stone or some scotch brite. If the brushes aren't making contact then there is no output.
Posted on Nov 26, 2014
Ok boy your welder have a riostathic control check contacts of your control maybe have dirt or grease
Posted on Mar 01, 2009
  • 92 Answers
Not familular with this unit, however, check the power rating of your tools against the rating of the outlet, some generators will cope with lighting only and will fuse if a power tool is used under load ,
lets know the outcome of this first then we can move on....................
Posted on Jan 23, 2009
  • Ron Jones
    Ron Jones Jan 23, 2009
    I understand, but when the outlet blows it can cause the AC/DC circuitry within the unit to blow causing a diode to go down,as I said, I'm not familular with this unit but base my thinking on other units I have used in the UK, go with the simple first before you start striping down the machine and ending up with a bigger problem, you understand , Is the arc AC and DC or just DC ? with the AC on the outlet/s ? assuming it is AC/DC then check the bank of diodes usualy 8 - 10 mounted on large heat sinks, being extreamly careful, check for voltage input if there is power then check the ouput, no output or very little output indicates that one or more of the diodes have gone down, you can expect more than one. Make sure of your safety before checking these.
Miller welder
Unfortunately, since this machine is CV (constant voltage) it is strictly for Mig or Flux-cored welding. Anything that is stick welded can be welded with Mig. All you need is a compatible Mig welder.
CP 302 MIG Welder MillerWelds
Nov 11, 2017 | Miller Welding Tools
1971 Big 40. Where can I get brushes?
try electrozad supply,waffles electric,windsor factory supply,praxair welding supply,liquid air welding supply,future weld supply good luck
Apr 25, 2016 | Miller Welding Tools
How to connect a Miller welding machine
Do you need information on how to connect the electrodes to use it, or how to connect to your garage/shop/house's power?
If it's a different type of plug than your outlet has the ability to receive, it likely means it's a 220 welder (as most welders are), and you would need a 220 outlet to plug it into. In which case, you need an electrician or someone else capable of wiring and installing a plug for you.
If you're wanting to know how to connect the electrodes to use the welder, the negative (black, generally) clamp needs to be securely clamped to a (preferably bare) metal area near where you want to weld. Usually problems with good ground connections are caused by not having the ground attached to bare, shiny steel. If it arcs at the clamp, it means it's not grounding well enough to work properly.
Aug 25, 2015 | Miller Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Engin boggs down while welding
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
Apr 08, 2012 | Miller Trailblazer 302 Welder Generator...
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
TIG welder tips
Go to your local welding supply store. A TIG welder is a specialized welder that cannot be found at a building supply store. Stores like Maine Oxy-Acetylene Supply or Grainger Industrial Supply will carry them. Look in the classifieds of publications like Uncle Henry's. There you might find a TIG welder that someone is selling—and it may be at a good price. Be sure to ask the owner questions and take a look at the TIG welder before buying it. Explore eBay. Yes, even eBay has TIG welders. You'll need to ask the buyer questions about the welder's history and more. Perhaps, if the seller is near enough, you might be able to pick up the TIG welder yourself and save on shipping. Visit online retailers. Retailers like Welders Direct or Welding Mart carry TIG welders and would be able to answer any questions you might have (see Resources below). Consider the manufacturer of the TIG welders themselves. Lincoln, Miller, Hobart and others have their own websites. Call the companies directly and ask a lot of questions. These vendors are the best product source for welders (see Resources below).
Aug 27, 2008 | Miller COOLMATE 3 115V TIG TORCH WATER...
Welding Tools Logo
3,899 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
