Cannot remove pump cover on front-load Siemens S16.76
I have a Siemens front-loading washing machine - S16.76 - the .
  • Anonymous Mar 28, 2009
    ماهي المشكله اذا ضهر صوره مفتاح
  • 15,935 Answers
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Clinking sound in a Siemens WFXD5200UC/01 front loading washer
I would suggest that a small thin metal item has got into the outer drum unit. This is the space between the internal spinning drum and the outer casing. This can sometimes happen by the object passing between the rubber door seal and the drum. Not easy to get out, however if it is small enough it may eventually find its way into the pump filter trap. There is a small round cover plate at the bottom right hand side of the machine. Behind the cover is the filter trap, open it up (when machine empty) and check for the object every so often. To open the filter turn the plug cover about a third anticlockwise and it should release. Pull gentle on the plug to remove from the machine.
Feb 14, 2016 | Siemens WFXD5200UC Front Load Washer
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Will spin empty but with a load will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water will not drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 10, 2010 | Siemens Washing Machines
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
The pump cover will not open
Top center of the pump cover there is a snall tag which must be depressed downwards prior to opening the flap.
May 11, 2010 | Siemens WM14S794GB Front Load Washer
I have a siemens washing machine - front load automatic. It is now winter here and it keeps showing that there is an error: F 37. What does this mean? that the water froze? what is the problem?
I Had a F37, thought it might be a frozen pipe problem but the filter was blocked. Turn off at mains. Remove the flap at the front bottom, pull the bung out of the hose to drain it then unscrew the pump cover and remove the obstacle. Seems to have done the trick for me.
Dec 20, 2009 | Siemens WFXD8400UC Front Load Washer
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
SIEMENS WXLM112GB FRONT LOAD WASHING MACHINE
Perhaps the exit hose behind your machine is not at the correct height, about 3 feet from ground. Your pump pumps the waste over this height, into your standpipe or sink; check this out.
Feb 10, 2008 | Siemens WXLM112GB Front Load Washer
Washing Machines Logo
1,036 people viewed this question
Top Washing Machines Experts
