Question about Acer Aspire 5742 Notebook
Touchpad not operating properly - Acer Aspire 5742 Notebook
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Just go to add remove hardware locate it there in input devices refresh it there
Posted on Jan 13, 2013
G1022
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jun 13, 2013 | Miele Dishwashers
Where and how i get the android 2.2 os software for download in my fujezone TP700 touchpad tablet?
my android is only showing me an android robot i need the operating system
Feb 12, 2013 | Tablets & eReaders
Cursor/touchpad is not working on my compaq
First option try to connect external USB type mouse, if it's working. second option need your touch pad check-up software driver in the device manager area. need update. or try to restore your operating system (OS). back to the time that working properly your touchpad advice.
Let me know if not yet working your touchpad. try that solutions first.
Oct 18, 2011 | Computers & Internet
Touchpad is not working properly...
If the touchpad is not working what you can do is to re install the driver for your computers touchpad.
Jul 01, 2011 | Computers & Internet
How to enable touch pad operation in ubuntu 10.04
Ubuntu provides configuration of the most common touchpad options in System > Preferences > Mouse, under the Touchpad tab.
Try the touchpad after unchecking the Enable mouse clicks with touchpad check box.
Check operation after Enable horizontal scrolling is checked. This may not have been the default setting.
Disabling Touchpad while Typing
  • Go to System > Preferences > Mouse > Touchpad and uncheck 'Disable touchpad while typing' and 'Enable mouse clicks with touchpad'
Feb 15, 2011 | Dell F3534 Touchpad
My laptop touchpad is not working properly .model is dell latitude D610 Please give me the best solution for this.
Try these steps it might help,
1. Download the updated driver for your touchpad.
LINK: http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=LAT_PNT_PM_D610&os=WW1&osl=EN
2. Select operating system
3. Category ---> mouse and keyboards ---> Alps driver ---> then click download
4. Once downloaded install the file
5. then restart your computer
Please rate this solution if found useful.
Thanks
Jan 17, 2011 | Dell F3534 Touchpad
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Touchpad does not work
in such case you can restore your program to old date...such as 5 days before.. hope your touhpad will work like before..
restore your program to the early date from when your touchpad was working...
reinstall touchpad driver....
otherwise you have to reinstall your Operating System...
Jun 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
My sony laptop touchpad not working properly
i have two solutions for you. the touch pad can be disabled on the motherboard so plz hold-down the fn key and press the function key that has the sign of a hand pointing something and the second is that ur drivers that enables thae touch pad to work has been courrupted so plz try reinstalling for the touchpad or try repairing ur operating system.
Apr 07, 2009 | Sony VAIO VGN-FZ240E/B Laptop
How do i operate the mouse on a toshiba 8200
hi, you probably have to disable the touchpad, for the microsoft mouse to work properly, i had same problem on my notebook. i conflict of software for touchpad made my microsoft cordless mouse not work, until i removed the touchpad software. i hope this is helpful,good luck!
Feb 13, 2009 | Microsoft Wireless Optical Mouse
Acer Aspire 5742 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
