Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Can't work out audio settings
I want to record into the mic and then hear it from my computer in audacity. Then I want to move the audio clip to movie maker and hear it at the same time as the video...this shouldnt really be that difficult but I cant seem to get the right settings on the audio. The only way I am hearing it the way I want is by checking a box that says "listen to this device" in system sound/recording/microphone/listen...only problem is...when I click apply noise screeches very high pitched out of the computer speakers... Is there a guide to adjusting audio?
SOURCE: GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Posted on Dec 23, 2007
SOURCE: Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Posted on Jan 16, 2009
alisondking
  • 4 Answers
SOURCE: no recording?
In garageband when you have the gtrack set up , it will show you 2 options for input source 'USB Audio CODEC'. This is because you have 2 lines in, the mic and the jack. Make sure you have picked the correct one to record the vocals...otherwise it is expecting the jack input and will record nothing.
Hope this helps!
gypsykingthing (AKA alisondking coz there's not enough space for my trad tag!)
Posted on May 14, 2009
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
PoiSonPeZ
SOURCE: the mic does not record stereo
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Posted on Oct 25, 2009
Why is it suddenly way too quiet?
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Dec 18, 2015 | Samson C01U - USB Studio Condenser...
I have a samson c01u and using audacity. i set the input level in the control panel to 100 and also in audacity, but the the volume is still too low. i can barely hear my voice. what do i do?
1. Did you select Left channel only in Audacity for the track you're recording?
2. Maybe it's a defective mic. Try it on another computer/software/USB cable/USB port and if it still doesn't work get Samson to replace it.
Apr 05, 2014 | Samson C01U Consumer Microphone
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
http://www.logitech.com/en-us/support-downloads
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
I connected the microphone on my computer and the system rec.ognized the microphone but I don't know how to use it with the computer to bring out sound
The thing is that the Samson C01U was not designed for live applications. Your solution, if you like delayed sound, is to use Virtual Audio Cable. Otherwise, I would get either a Samson GTrack, or invest in a cheap but functional mixer with a good mic. If you want to record however, you go into your audio recording settings and select the C01U as the recording mic. If you record and hear little sound, go into sound manager... Click on properties and select on Samson C01U. A one channel volume control will pop out. change the volume and record. BTW, a good audio program is Audacity... It's free. I hope that I have helped you...
Apr 27, 2011 | Samson C01U Consumer Microphone
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Labtech 524 microphone does not pick up sound
I have written a guide on How to convert Records and Tapes to CD. I have found that when someone asks me a question like yours here is what I tell them. Go to http://audacity.sourceforge.net/ Download the program Audacity. It is a completely free program. It works great for many audio applications. It does not have spware or adware or anything like that attached to it. In fact many studios use this program. Click on the Download Audacity 1.2.6 link to download the program. Install the program and open the main window. In the middle of the window you will see a field that is labeled Microphone. If the field is not set to Microphone then change it by clicking on the drop down menu. There are two slider controls to the left and right of the small microphone icon. Click on the sliders and set them at about 1/2. These 2 controls are your microphone input level and your Audacity main volume control. Now simply click on the round red record button. Talk into your microphone. If your mic is recording you should see recorded sound waves in the middle of the window. Click on the square stop button and then click on the rewind button. Next click on the green play button. Make sure your computer speakers are turned up. If this doesn't work your sound card may not have recording capabilities or you may have your mic plugged into the wrong connection on your tower. You can move the mic to a different connection and try recording again. Just don't plug into your speaker connection this could damage the microphone. You can check to see if your sound card has recording capabilities by competing the following On your desktop click on start - control panel - sound, speech, and audio devices then click on sound and audio devices. When the small Sound and Audio Device Window opens, click on the audio tab. Under the title sound recording, you should have a sound card listed in that field. For example my card is a SoundMaxDigital Audio. The field is right next to the small microphone icon. If there is no card listed you can buy a cheap one online or even at Wal - Mart. They are very easy to install. You just find an empty slot on *********** board and your computer should recognize the card.
Mar 13, 2009 | Labtec Verse 524 Consumer Microphone
Mic is plugged in correct spot but no voice AT ALL goes through
Mar 12, 2009 | Audio Players & Recorders
Casio CTK-720 USB computer/music connection
1.Download Audacity -
http://audacity.googlecode.com/files/audacity-win-unicode-1.3.9.exe
2.buy a cable for sound input, with 3.5" connector on both sides (like
the end of mic/phones)
3. connect cable from Phones/Output on keyboard to a PC where you
connect your stereo
4.run Realtek program for sound, go to Mixer/Record and enable Stereo Mix,
then in Audio I/O click on connected device and assign Line In.
%. Now run Audacity and start recording sound,you should hear your keyboard
May 16, 2008 | Televison & Video
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
54 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
