Lg rz26lz50 jitter vertical - Televison & Video
2 Suggested Answers
  • 927 Answers
SOURCE: Intermittent vertical jitter on Mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Posted on Jul 31, 2008
Vrtical problem
What is the problem you faces with this TV? Vertical rolling? Vertical jitter? Provide more details please.
Jan 04, 2013 | RCA Televison & Video
When tweaking the motion settings low makes everything jitter really bad and high is a bit better. Even at custom 10/10 it still jitters enough to annoy me. Is it a defective tv? The strange part is...
Try checking the Hz settings on each channel you use. It may be that what you happen to put a setting on is only effective on that channel. Which means if you had to originally set it for 60 or 120hz on the hdmi channel, then you may have to do the same for your tv/satellite channel.
Jan 13, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Intermittent vertical jitter on mistubishi tv 65000
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi projection TV VS-4561 Vertical Hold issue
Good Day, Maybeitstime:
Joe the cheapest way is to repair it yourself and this is what you need to do:
VERTICAL JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTIC's (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND). As you can see this might be over you head but for a 1994 model you did get 14 years of watching TV enjoyment. 'Might think about replacement. Good Luck, big IRISH.
Apr 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Jitter and tearing on bright pictures
1. VERT JITTER/HORZ UNSTABLE-CHECK 'GE' CONNECTOR PIN 5 FOR 1VPP Y SIGNAL INTO PIP PCB THEN CHECK 'GE' CONNECTOR PIN 11 FOR 1VPP Y SIGNAL FROM PIP PCB. IF SIGNAL AT PIN 5 IS GOOD AND PIN 11 IS CLIPPED OR REDUCED. CHECK ALL ELECTROLYTICS (I.E.C7001, C7014, C7026, C7036) AND ALL CONNECTING TRACES TO THESE CAPS FOR CONTINUITY 2. HORIZONTAL TEARING, VERTICAL JITTER. SIGNAL RELATED CONDITION. APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Jan 21, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Mitsubishi Model # VS-7085
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Sep 05, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Intermittent vertical jitter.
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
Nov 08, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
