Lost the sound dtv/cbl input yamaha rav284
No sound through surround sound from tv
SOURCE: sound
I'm assuming you you have a basic TV to receiver hookup. Make sure you have the TV audio video output going to the receiver input.
Posted on Sep 01, 2007
sparky1500
  • 1066 Answers
SOURCE: 1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
Posted on May 17, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
Marcos_Ce
  • 71 Answers
SOURCE: DTV Cable No Sound
Check if DTV/CBL is set receive COAXIAL or OPTICAL inputs. Good luck
Posted on Nov 23, 2008
  • 92 Answers
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Posted on May 20, 2009
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
I am unable to surround when I have XBOX and Blueray via 2xHDMI and 2xOptical, I am only able to get 1 device to work at a time, pleast help
This is normal. You cannot run 2 optical inputs at the same time. You can only use one or the other. For example . . if you are playing your xbox, you would use that corrosponding optical. When you are done and whant to watch your blue ray, you would have to change inputs to that corresponding optical.
May 10, 2012 | Yamaha RX-V365 5 Channels Receiver
Unable to get surround sound thru all speakers
Some features do not give surround sound such as tuner. If input cables attached to analog dtv/cbl and speaker cables attached to wire end output serround should work fine when set to dtvcbl on front display.
Mar 31, 2011 | Yamaha HTR-5850 Receiver
I can't get a sound from my yamaha rx-v367. my tv is lg le5310
Last update: 05/02/2008
Connect the audio outputs jacks from the TV to any available audio input terminals on the Yamaha receiver, other than the phono input. You can use any analog audio Left (White) and Right (Red) inputs on your receiver such as the DTV/CBL, SAT or VCR input. There are no special settings needed on the receiver, other than selecting the correct input. There may be some settings that will need to be changed on the TV. Consult the TV ownersEmanual for setting up the TV to output audio to an external source. If youre TV has a digital output (Optical or Coaxial) it can also be run to one of the digital inputs on the Yamaha receiver, such as DTV/CBL or DVD. There may be some settings that will need to be changed on your TV. As always, consult the TV ownersEmanual for setting up the TV to output digital audio to an external source.
NOTE: When the source of the audio signal is coming from an HDMI device connected to the TV, the TV may not output in 5.1 surround sound.
Jan 01, 2011 | Yamaha RXV367 Receiver
Yamaha HTR-5750 no sound when I turn to the DTV/Cable setting
If you are not getting sound on "Any" input except "multi channel" you have a bad DSP chip in the receiver.In short, you need a new receiver, it's a 500.00 repair. If you get sound on "All" inputs except "DTV/CBL" You need to get into the main menu of the Yamaha and select audio, toggle to input, then DTV/CBL and select "Auto". If you still do not get audio, it would be due to the version of HDMI software in your receiver. If it's under warranty, Yamaha will update hardware and software for you at N/C. If it's out of warranty, use digital coaxial or optical as your audio input for TV and run your HDMI directly to the TV. (The repair for this too would run 250-350) I hope I've covered all the possibilities. If you need further help, post a comment and I can help you more.
Aug 25, 2009 | Yamaha HTR-5730 Receiver
Getting Audio to work with our Cable Tv
The HTR-6130 does not decode the audio from the HDMI inputs. It only acts as a switcher. You will need a separate audio connection from the cable box to the HTR-6130.
Dec 27, 2008 | Yamaha HTR-6130 Receiver
May 17, 2008 | Yamaha HTR-6030 Receiver
DTV Cable No Sound
Apr 09, 2008 | Yamaha HTR-5930 Receiver
Sound
Mar 02, 2007 | Yamaha HTR-5830 Receiver
37 people viewed this question
 Grubhead
Grubhead
