Question about Maytag MZD2665HE Side by Side Refrigerator
JennAir JSD2789GES ice maker /water dispenser
I cannot get water thru door or to icemaker. All solenoids are okay (continuity checked), Replaced control board. Ice dispenser mechanisms all work. Actuator switch okay. Water available at back of fridge. I don't hear the solenoids kicking in when actuator switch is activated for water but have 120V at correct wire (black pin 6). Don't hear ice maker fill valve kicking either.Only common item is white/blue wire switched thru door interlock which is okay. Is there another wiring interlock in ice maker which doesn't appear on schematic ?
  • Anonymous Mar 21, 2014
    Icemaker will not fill, rotates periodically but does not make ice. The fuse on black wire between main 4wire harness and smaller 4wire harness on icemaker is solid--shows continuity. Water solenoid never sounds energized--normally uou can hear the fill across the house :). Should there always be 120vac from black to white or to GND on the main 4wire harness?
    President:
  • 331 Answers
Dave, this is a bad valve. Replace it and all will be well in the world again.
Posted on Aug 09, 2007
    Sergeant:
  • 236 Answers
If the water is stored in a container matrix in the fridge (to cool it down b4 dispensing) it may have frozen up. best give the unit a complete defrost to see if this is occuring, if so the thermistors may be faulty.
Posted on Jul 12, 2007
Whirlpool French door not making ice, but can get water. I had the water valve replaced and it still does not make ice help
Okay, here's a bunch of info in the order I would troubleshoot since the one year warranty expired.
1) The water filter might be clogged. Try just removing it to see if it makes ice. If it does change the water filter.
2) The water inlet valve might (still) be defective. The water inlet valve is an electro-mechanical valve. The coil can show good for continuity and still not let the water thru although you didn't say if it worked when he left. if recently replaced it should be under his warranty.
3) The water pressure in the house might be too low. The water inlet valve which supplies water to the ice maker is designed to work with a minimum of 20 psi of water pressure.
4) The door switch might be defective. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker and dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
5) It could be that the ice maker assembly itself is defective. The freezer temp should be between 0-5 degrees for the ice maker to cycle properly. There are several components in the control module of the ice maker that can fail and most are not sold separately. Also, ice makers have a relatively short lifespan and so it might not be worth fixing. If other, simpler parts like the water inlet valve or shut off arm have been ruled out, and the only thing left is the ice maker itself, replace it as a unit. Not as expensive as you may think...Under $100
6) The icemaker module at the front might also be defective. The module has a motor that cycles the ice ejector arms around to push the ice cubes out when the ice maker thermostat closes. It also has contacts in it for the mold heater and water inlet valve. The motor or contacts of the module can fail. Usually there are test points in the module that a service person can use to determine if there is a problem with it or one of the related ice maker components.
7) The icemaker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat which monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature the ice maker starts a harvest cycle by ejecting the ice cubes and refilling with water. If the mold thermostat is defective the ice maker doesn't advance. The thermostat can be checked for continuity. Replace it as needed.The freezer temp should be between 0-5 degrees for optimum performance.
Sep 17, 2014 | Whirlpool Gold GI6FARXXY 25.5 cu. ft....
Jennair jcd2289 side-by-side does not make ice
If you are getting water from the dispenser, then the water valve is good. The icemaker will need to be replaced since when the icemaker cycles and empties the ice tray, it should call for the water to refill and it is not doing so. Here is a link to the replacement icemaker.
Oct 16, 2012 | Refrigerators
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Water not being dispensed thru the door
There is a solenoid-actuated water intake valve in the back of the refrigerator. Actually there are two - one for the icemaker and one for the water dispenser - which are usually combined into one assembly. Sometimes the electromagnetic coil burns out in one of them. The other possibility, which is less likely, is a bad mocroswitch at the dispenser where you press the lever.
Jul 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MZD2665HE Side by Side Refrigerator Logo
234 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
