My Gobii e reader has frozen what do i do
Has frozen
Hi there, WebRepOverall ratingThis site has no rating(not enough votes)
My Gobii reader froze today, conveniently 12 days after my warranty has expired! :( I called Kalahari and they said they have to contact their supplier and will be getting back to me on Monday. I suggest you call them too, the more complaints they receive about this problem may fuel then to look into it more seriously. Good luck!
Posted on Jan 25, 2013
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
I forgot my screenlock password.How do i factory reset gobii tablet
Try Settings, Backup and Reset or wherever it is found.
Jan 10, 2015 | Tablets & eReaders
How do you replace battery in gobii ereader
There are several fora on the net, discussing the battery replacement for the Gobii ereader. It looks as if there is no service for this reader. Some people even say you should trow it away and buy a new reader.
I think it should be possible to open the reader and order a battery, as soon as you can get it out. Just use google to fine a replacement battery.
You also could visit a phone repair shop and ask them what it cost to replace a battery, but first check what a new one will cost, because in a shop it could cost more then a new reader.
Success
Nov 24, 2014 | Tablets & eReaders
Gobii how to replace battery in reader
Most tablets are glued together, some have plastic connectors around the edge.
I could not find anything related to "Gobii" but I did find "Kobo"
https://www.youtube.com/watch?v=2SmYg4q9ai4
This video should only be viewed for reference, your device may be different and require different tools or pecedures to take apart.
I tried to connect with talk talk for my kobo reader the password was not accepted my reader has now frozen?
my Kobo has a reset hole on the back, push a fine pin in there.
might do the trick.........worth a try
Oct 27, 2014 | Tablets & eReaders
Hi my gobii ereader frezzes and nothing works. I downloaded books and after that nothing. The battery is charged. The screen comes on and off automatically. How do I reset the Gobii?
After taking delivery of my Gobii reader, I loaded a large number of books onto the internal storage of the device. After disconnecting it from the PC, it became unresponsive, then got stuck in an endless reboot loop.
To get control of the product again, you need to do the following:
  1. Hold down the power button for 6 seconds until the device turns off
  2. Press the power button for approx. 2 seconds to turn it on again
  3. Hold down the "back" button (just above the navigation square) immediately after letting go of the power button, while the device boots up
  4. It will show you a few files in the library section and you will be able to bring up the menu by pressing the menu button (top of the array of buttons)
  5. Go to settings > format memory and wipe the device to it's original state
If you struggle, make sure that there is no SD card in the device.
Apr 10, 2013 | Computers & Internet
Sony reader is locked up
Hi shunkjustice!
I'm not sure if you are talking about locked because you forgot your password, or if the reader is frozen, but here are the links with some steps to try
If locked and forgot your password:
http://digialreader.freeforums.org/forgot-4-digit-password-prs600-t8.html
If frozen:
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Jul 26, 2011 | Sony Reader Touch PRS-600
Just purchased a sony prs350 pocketbook editiion yesterday and it it is frozen . What can I do?
Hi pmteach4u!
ecause of e-ink technology, sometimes it may appear that the reader is frozen, you can try to reset the reader
1. Disconnect the Reader from the Computer
2. Hit the reset button for 3 seconds at the bottom of the unit with a paper clip
3. Slide the power switch, the screen will blink and will show "Opening Book". Allow the Reader to load.
If the issue still persist, follow the steps on this link:
GoodLuck!
eBookBoy
Jul 24, 2011 | Sony Reader Pocket PRS-300
Computers & Internet Logo
295 people viewed this question
David Payne
David Payne
