Question about Science & Laboratory
What is the difference between a pipette and a burette?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
Although they are both used for measuring liquid, the burette is usually for larger quantities of liquid and the pipette is for smaller quantities
Posted on Jan 13, 2013
I get the message "Rinse unit" I do so and the machine rinses in a normal way. Instead of "Select product" the "Rinse unit" appears again. I can not continue from here. Any ideas?
you might escape this fix without using specially tools or screwdrivers. you are receiving this message because the rinse head sensor isn't working properly.
during the machine movement the rinse head down sensor was not triggered.
1. check the gap between the top of the rinse nozzle & the bottom of the pipette. measurements should be around 1.5 to 2mm
2. you might have to invite the newelectronx 102 to the party and check the sensor. if necessary open the machine with the correct screwdrivers and adjust the sensor. this should get you through the rinse cycle.
Aug 05, 2015 | Franke Saphira Espresso & Coffee Maker
I have a 2005 mazda 6 that is not firing due to oil getting on the spark plugs.. how can I remove the oil from the holes the spark plugs screw into? or if not possible what should I do? I really need!
The spark plug tunnels of that type of engine sometimes get oil in because the cam cover or valve gear cover gaskets are leaking.
The oil should be removed before the spark plugs are disturbed to avoid it running into the cylinders and causing trouble. The majority of the oil can be mopped out with cloths poked down the holes with a screwdriver or a rod. If there is a lot it can be sucked out with a good turkey baster (with an extension) or a tube fixed to a pipette bulb.
When the majority of the oil is gone it will be time to introduce some solvent such as white spirit or brake cleaner and agitate it with the rod or a long brush until the remaining oil is dissolved and can be mopped out until almost dry.
It will then be safe to remove the spark plugs and very, very carefully complete the clean-up.
The source of the oil should be investigated and rectified before driving the car and it would be a good idea to check the crankcase breather and pcv valve operation.
Feb 28, 2015 | 2005 Mazda 6
When making a mixed drink that calls for 2mls or 10 mls or 20 mls of alcohol,what is that equal to in u.s. ounces,please answer for each mls above,,thank you
10mls equals .338 US fl ounces (roughly one third)
20mls equals .676 US fl ounces (two thirds)
2mls equals .068 US fl ounces (too little to measure without a pipette)
Feb 12, 2015 | Motorcycles
Make a eight letter word from the letters stsrlienyp
http://wordfinder.yourdictionary.com/unscramble/eilnprssty
Try this link or type it in. I simply did a search for "word generator."
Hope that helps.
Nov 21, 2013 | Puzzle Toys
Will not start, no spark
probably some oil or other liquids wet the ignition system, have you cleaned or changed the spark plug? Check if there is some liquids or dirt in the electronic ignition box or in the wire terminals in the connectors, check also spark cable, unmount the spark pipette, use a pair of insulated gloves, put high voltage cable terminal at 1-2 mm from a metal part, turn the key & crank the engine, check for spark.
Nov 13, 2013 | Honda Motorcycles
Why do perfumes smell different on different people?
parfumes smell different on different people because each individual had different natural smell and it alters the outcome. Changes in life, diet, taking medication will alter your natural smell as well and you may end up with a different smell even from the fragrance you have used before. Always try fragrance for at least 15 min on you skin before deciding if you like it or not.
Nov 23, 2010 | Health & Beauty
I put liquid dishwashing soap IN THE RINSE AGENT DISPENSER. What can I do?
I suggest purchasing a pipette (long thin flexible plastic eyedropper thing) from hobby lobby, Frye's, or from a scientific lab supply.
Draw up as much a you can from inside. Apart from that unless you remove the panels from the door to access the reservoir, then it may take several more washes to remove the soap from the the rinse additive dispenser. One more thing, you could start the machine in the rinse mode to wash the dishes and stop it when done and restart in the wash mode to rinse. When that is finished, stop and restart in the drying cycle. Good Luck!
Jul 03, 2009 | Dishwashers
I REPLACED THE VALVE COVER GASKETS AND CROSSED A COOLANT HOSE WITH A PVC HOSE WICH PULLED COOLANT IN THE CYLINDERS REPAIRED THAT PROBLEM BUT NOW HAVE A NOISE THAT SOUNDS LIKE A LIFTER
step 1Materials Valve Cover Gasket Kit ($13 at autozone, big box with two tubes of RTV and 11 neoprene bolt seals) --- alternatively, you can buy the preformed gasket for about $30 - if y…
step 2Remove the intake You'll need your screwdriver to loosen up any clamps. You really only need to remove the section that bolts up to the TB -- this just makes working faster. If you d…
step 3Remove Solenoid I think its an EGR solenoid - regardless, its bolted on to the side of the valve cover. If you can unplug it - be my guest. I couldn't, so I used a socket and unbolted it.
step 4Remove Spark Plug Wires etc. Pull the wires. Also disconnect the PCV canister and breather hose.
step 5Remove Valve Cover Bolts and remove the valve cover Using the Torx bit, remove the valve cover bolts and their gasket washer ring thingies. I think they are all the same size, so no worries about keeping them in order. Th…
step 6Optional - **** out any oil If your gasket failed like mine, you're gonna need to pull some excess oil out of the plug wells. A plastic turkey baster comes in handy here :P I used a pipette - it is wh…
step 7Clean the Mating Surfaces Using the gasket scrapper, remove any and ALL of the old gasket material. Using a #1 (or maybe #2) flat head screwdriver will help get the old material out of the groove…
step 8Apply the RTV Gasket Material Follow the directions on the tube of RTV. Evenly apply a bead of RTV sealant on the valve cover. I added a little extra to the #1 and #2 spark plug well. I did this because…
step 9Put the valve cover back on This is important. Place the valve cover back on the head exactly where you want it without hitting anything. If you smear the wet RTV, you're going to have to clean it off…
step 10Final Steps Now you're pretty much done. Using your socket, replace that solenoid and any hoses you took off. Replace the intake, breather hose and PCV line. Then let your car sit f…
May 29, 2009 | 2002 Jaguar S-Type
Set different ring to different callers.
Well i also use the same phone... but the feature to assign different ring tone for different user is not a feature that is a feature of this lovely phone from Nokia Inc.
Jan 29, 2009 | Nokia 9300 Smartphone
Difference charateristics for windows XP,VISTA,NT,98 and UNIX ?
It would take a week to list the differences. It's kind of like, the difference between your left shoe and your right glove.
Jan 12, 2009 | Google Computers & Internet
Science & Laboratory Logo
479 people viewed this question
Top Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
