Question about Miele Ovens
THE INNER GLASS OF OUR MIELE OVEN DOOR HAS CRACKED AND CHATTERED .HOW DO WE GO ABOUT GETTING A REPLACEMENT AND HOW LONG WILL THIS TAKE .I HAVE THE MIELE - DELUXE H 612- EYEL LEVEL OVEN
I LIVE AT NO 15 FAIRVIEW DRIVE UMHLANG ROCKS IN NATAL , SOUTH AFRICA MY CONTACT DETAILS ARE CELL 0828200711 (GARY CHERRY)
  • 833 Answers
SOURCE: how to replace inner oven door
Generally, the job is just alot of screws. Depending on the model, most screws are found either inside the door or on the lower edge. Some models...mostly GEs... have a way of removing the door from the hinge. Doors are heavy and are usually spring counterweighted.
Is it an easy job? Depends...if you're mechanically inclined it is straight forward. You will need an assistant as these doors do come apart and they are heavy. Often, the manufacturer or a parts house has an exploded diagram to let you see what you're facing.
Oh, and use a good quality screw driver and apply pressure when turning out screws. You don't want to ruin the heads!
Posted on May 27, 2008
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
Part here: Inner Door Glass
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
  • 327 Answers
SOURCE: Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
Posted on Jun 02, 2010
We have a whirlpool built in oven MODEL # RBS305PRS00 There are drippings on the inner glass window that I want to get to so I can clean the glass. How do we get to the glass?
Typically, as in ours, there are screws holding the inner door cover on. Look on the back, bottom or sides. These will hold the inner door on, then once removed, observe screws, typically Philips, holding the glass frames together. Careful not to over tighten the frames when reinstalling or you may crack the glass. Do not use a power screw gun either.
Apr 02, 2017 | Whirlpool Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replacement for inner glass
Replace the entire door, do not try to straighten it. If you or the retailer paid someone to deliver it, they are responsible for replacing it. The retailer where you bought the oven should be able to replace the door for you or you can contact Miele's Service and Repair Support at
Jan 14, 2014 | Miele DG163 Electric Single Oven
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
H4080bm Miele microwave handle fell off
Hi Try not to open door with handle as this may cause to glass to smash. When you open the door you will see two pin sticking forward near the top of the door just further back on the top of the door is two small barbs push down on these barbs located in line but further back from the pins.This will release the top of the outer door.The bottom of the glass is hooked into the hinge. with the top released lift door glass away.You should find screw in inner door refit screw with some loctite.
Aug 23, 2010 | Miele H4080BMSS Oven
Is it necessary to repace the entire inner door
You should be able to just replace the inner door glass. They are usually available as a seperate spare part.
Go to the manufactures web site, and if neccessery send an e-mail to them.
Feb 16, 2010 | Ovens
INNER GLASS REPLACEMENT FOR KITCHENAID KEM308GSS0
I took it apprt removing the door according to manufacturers in structions and I found out it only needs a peice of glass, so I put it back together and put the door back for now and I ordered the glass from a parts supplier on the interenet after I dentifying the part online from an exploded Isometric assembly drawing on the vendors site. When it gets here I will install it. very simple a teenager could do it. The big question is why did it crack inthe first place?
Dec 11, 2008 | KitchenAid Architect® KEMS308S Electric...
RBS305PDS Broken Glass on Oven Door
inner door glass part number 4449259.. youll need to remoe the door from the unit and lay it on the table, thats the hardest part, theres a few different ways the door releases, so refer to your manual if available, then its just a matter of removing the screws form the door until you get to the broken panel, might thake a little time but as long as your patient no need to call service man. probly save $150
Nov 23, 2008 | Whirlpool RBS305PDS Electric Single Oven
Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
