Question about Zooper Cool Zone Buddy Stroller
Reversed Seat, Can't figure out canopy
I got the seat to turn around so that my little one can face me, but I can't figure out how to make the canopy work in this position.
If I leave it as is it has no support and just hangs. If I unzip the piece that snaps onto the back of the seat when facing forward and snap it to the back of the seat now that it is facing me it can't zip onto the rigid hood.
I hope someone can help.
I just turned my seat and was confused by this too. I figured out that the plastic axis points have small buttons that you push in to remove the front half of the hood (be sure to unzip it). You then reverse the hood. you have to forcibly twist the plastic slats, that attach the hood to the axis points, around to the other side. It makes alot of clicking noices and is hard to turn but they do turn. Then you simply slide the slats back into place and zip the hood back together.
Posted on May 22, 2010
How do you separate the two parts of the plastic to remove canopy on graco snug ride car seat?
There are two styles for the Graco Snugrides. Older canopies simply have a plastic "claw" the you pull away from the seat where the hinge of the handle is located.
Newer seats have a button on the side of the seat where the canopy attaches to the seat (also near the hinge of the handle).
I hope that makes sense.
Jul 12, 2014 | Baby Gear
Cosco Alpha Omega Elite 3-in-1 Car Seat
DEAR SIR,
To start off, this seat can be purchased for around $100! For $100 you can get a seat that is 3-in-1 just like the name says. This means it can be used rear-facing, forward-facing and as a belt positioning booster seat. If your child weighs anywhere from 5-100lbs they can use it!
• This seat has comfortable fabric so your child sits comfortably during every car ride.
• It includes a push in harness adjustment lever.
• Has fold up armrests.
• LATCH compatible to ensure the safety of your child.
• And lastly, it has a harness and headrest that adjust together to never need rethreading.
This seat has all the features your little one needs to stay safe.
Find the best Cosco Car Seats at FindMyCarSeat.com.
THANK YOU...TAKE CARE
Oct 12, 2010 | Toys
Fan continues to wobble at all speeds.
Check to make sure you don't have a wire pinched between the Triangular ball and the canopy. If you don't have anything pinched between it, make sure your electric box isn't loose. If it isn't, pull down moderately on the fan with it off and move the fan around it's full axis several times, which should seat the ball into the canopy better. Almost every Hunter with the HandsFree canopy I've installed, I've had to do this little "procedure" which the manual says nothing about.
Apr 01, 2010 | Hunter 20763 52'' The Stratford II Ceiling...
How to reverse zooper buddy stroller seat.
There are 2 red buttons on the bottom back on the seat. Push them together really hard until they lock in place. Pull up on the whole seat...really hard. The whole seat comes off. Then turn it around and snap it to the other knobs
Jun 09, 2009 | Zooper Cool Zone Buddy Stroller
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Pliko p3 How do I set it so that baby is facing me
If you recline the seat fully and fold the footrest up, then take off the canopy and put in on backwards, you can lay your baby down (almost) flat and it will be as if you were pushing a pram-style carriage. The stroller frame itself does not change (as with the Pliko Switch); you just reverse the canopy and lay the baby down so that his/her head is where the feet would normally go and his/her feet are where the head would normally go. This set-up looks especially cool, in my opinion, and you can look at your baby while strolling.
If I haven't done an adequate job explaining, there is a website that has pics of the stroller with the reversed canopy. I can't remember the exact name of the site, but if you google "strollers and prams + Pliko" you should be able to find it. Good luck!
Dec 28, 2008 | Peg Perego Pliko P3 Classico Freestyle...
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Reversible seat
On mine it's extremely easy. You pull a small handle under the seat, lift it up, turn it around, and then push it into place
Aug 06, 2008 | Quinny Freestyle 4 Marina Stroller
Graco ex duoglider in colburn
the car seat faces the mum and just slops in hun
Mar 29, 2008 | Graco DuoGlider Travel System 7444SAR -...
Quinny Buzz Canopy
The canopy should just push onto the seat frame, they do need a bit of pushing though. its easier if you get the connector half on and then just push, will hear a popping sound. it took me a while to figure it out on mine and the instructions aren't the best.
Nov 25, 2007 | Quinny Buzz Jogger
Zooper Cool Zone Buddy Stroller Logo
135 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
Dorel UK
Dorel UK
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
