Question about Lanzar HBP310 Car Subwoofer
Wire I need an original diagram of wire conections of this 3 dual coil and 6 ohm subwoofer.
  • 43 Answers
Need a little clearer description of what your trying to do. 1) what ohm load are your subs dual 2 or dual 4
Posted on Jan 13, 2013
  • vasi_hordobe
    vasi_hordobe Jan 14, 2013
    I have a lanzar hbp-310 subwoofer whit one signal imput (one +, one-) and three 6 ohm dual coil subs inside and I whant to have at finish, a total of 4 ohm on all subs toghether.
  • Woody Wood
    Woody Wood Jan 14, 2013
    i know they are measuring between 3.1-3.6,but still considered 4 ohm subs(poor manufacturing these days,best advice go to THE12VOLT.COM breat source for car audio solutions. good luck
4 Suggested Answers
Doorguy27
  • 30 Answers
SOURCE: wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Posted on Feb 10, 2009
etirbynnor
  • 655 Answers
SOURCE: how do you wire up a dual voice coil lanzar 15 for
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Posted on Jun 28, 2009
brianw74
  • 400 Answers
SOURCE: How to wire lanzar opti1532d dual voice coil 2 ohm
Do you have just one???? If so and your amp can handle a 1 ohm load, hook one voice coil to the other (positive to positive, neg to neg) then bridge it to the amp...If not you will have to take the positive of one voice coil and the negative of the other and bridge it to your amp....The other hot of one voice coil and neg of the other needs hooked together (jumperwire). That will give you a 4 ohm load.
Posted on Nov 14, 2010
Wire diagram for subwoofers
need more info,what ohm load are spkrs? are they single voice coil or dual? if dual what ohm dual 2 or dual 4? what amp are you planning to use? stereo amp or mono block? if mono block what make and model? what style box are you using,sealed or ported?
Jan 09, 2013 | MA Audio MA 1200XL Car Subwoofer
How to hook it up for one ohm
oh yes the JBL GTi W15GTI Mkll. this subwoofer is a dual 6 ohm voice coil subwoofer. This is impossible to run this sub alone and get 1 ohm you will need another JBL GTi W15kll. the lowest impedance you can go to is 3 ohms. you can achieve this by connecting the positive terminals together and then running a wire from the two positives to the positive terminal on the amp. then connecting the negative terminals together and then running a wire to the negative terminal on the amp. this is a real nice sub it just has that one down fall of having a six ohm voice coil.
Aug 01, 2011 | JBL GTi W15GTi MkII Car Subwoofer
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
Wiring diagram for dual voicecoil subwoofer
To wire a DVC subwoofer, treat it (in the diagrams) as two seperate speakers, called coil one and coil two. This makes things easier.
To wire them up, wiring them in series would be safer, but if the amp is 2 ohm stable, put them in parallel. Look up dual voice coil wiring in google imagesfor more information and pictures.
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
How do you hook up 2 15 inch cvr to 1 ohm
Hello juanelreypla,
If your CVR's have dual 2 ohm voice coils, they can only be wired for 0.5 ohm, 2 ohm, or 8 ohm final loads.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
If they have dual 4 ohm voice coils, they can be wired to a final load of 1 ohm. Wire the voice coils in parallel and then parallel both subs. Like the diagram in Wiring Option #1 shown here.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
Nov 10, 2009 | Kicker CVR12 Car Subwoofer
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
How to wire it up
your best bet is to go onto www.the12volt.com and find the tab at the top that says subwoofer wiring diagrams. Next go to google and search for audiovox subwoofers and search through. You will definately have no issue if you find the model it will tell you the impedence of the subwoofer. 2 ohm dual voice coil, 4 ohm dual voice coil, 8 ohm dual voice coil. anyway it is a dual voice coil
Jun 13, 2009 | Audiovox Car Audio & Video
Lanzar HBP310 Car Subwoofer Logo
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
