Question about Sony Cyber-Shot DSC-F505V Digital Camera
How much Sonyspars?
How much would an imaging unit cost? Who repairs cameras with 3rd party parts?
The screen on my sony dsc-f505v is not clear how much is the display screen to renew.
Thanks.
Posted on Aug 26, 2008
  • 89 Answers
We can make this Sony CCD at reasonable prices. Lead time 3 to 4 weeks.to despatch. Let me know by e mail.
Posted on Jul 09, 2007
    Problem Solver:
  • 32 Answers
You can serach on net for your area... sangita
Posted on Jul 08, 2007
SOURCE:
1990 honda crx has 2 bent rods. How much should this cost to repair?
That depends a lot on who does the repairs. Dealers usually are more expensive because of the training the mechanics get, but you know you won't be getting 3rd party parts that may be inferior. A bent rod may have damaged other parts too, so be prepared.
Sep 07, 2017 | Honda Cars & Trucks
My konica minota c451 is showing erro code c2551 and the print out is not sharp?
Remove the cyan (Blue) image unit. shake it along its axis. Are using 3rd party toner and image units replace with OEM. Open close front door to reset. Replace the image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 09, 2015 | Konica Office Equipment & Supplies
C-2551 error code
Check the cyan image unit. Pull it out and shake side to side to spread the developer in side the image unit along the whole length of the image unit. Then reseat the image unit. if the code comes back replace the image unit with a NEW one do not use old one hanging around. Also recommend using OEM cartridge.3rd party can cause problems. could also be a circuit board (Expensive). But have a tech re-flash firmware before replacing board
Aug 06, 2014 | Konica Minolta Bizhub C300 All-In-One...
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
May 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub c200 error code c2557
replace the black image unit using 3rd party toner? if so replace with OEM and USE OEM image units
Apr 25, 2014 | Konica Minolta bizhub 200 Printer
HP M375 prints out of alignment
Are you using 3rd party consumables?
even if you are not I would recommend you replace all 4 imaging units ( toners) and allow the machine to perform the calibrations before using,
also I would clean the image belt calibration sensors ( located along top edge of ITB ) as they often get coated with toner particles,
also - is there a grinding noise - this could indicate a poor fuser- which if the vibrations are strong enough will definatley alter the printed image
p.s. 3rd party toners arent cheaper, the damage they do is unseen by the user until its too late by which point all the savings you made and more will be needed to repair/replace.
Mar 05, 2014 | HP LaserJet Pro 300 color MFP M375 MFC /...
I have developQC2235plus error code C13d3 EEPROM access Y
well that mean you have a yellow image unit fault using 3rd party use only OEM. also check the yellow image unit.
Feb 15, 2014 | Konica Minolta bizhub Office Equipment &...
Hp laser jet 3500 printer has an error code 59,99 what can i do /
main motor has failed to reach revolution within specified time- in other words - something is siezed solid and is preventing the machine from turning over into normal warm up operation-
suggest if you have recently replaced a toner cartridge/ fuser/ Image transfer belt then remove the new item and cycle the power without the unit installed. if tour machine warms up then complains about no cartridge then you have confirmation of the new unit being faulty-
if you are using 3rd party toners/ fusers then that could also be your problem. 3rd Party toners do NOT save money rather they will incur repair costs as they are not correctly prepared for re-use.
Jan 16, 2014 | Office Equipment & Supplies
GeoVision NVR Software for 3rd Party IP Cameras
Not exactly sure of the question but Geovision does allow for many 3rd party IP cameras to be connected. Check the Geovision website for a full compatibility list. I have personally worked with Hikvision and Vivotek with no issues. You will need to purchase and install a dongle. The dongle comes with software that you will need to install before using the USB dongle. The dongles come in 1, 2, 4, 8 & 16 camera capabilities. There is usually no cost difference to buy two 2 camera dongles or one 4 channel dongle. So get whatever you need. Just be aware that is will look odd having 4 USB sticks protruding from your NVR. There are also some internal dongle options that connect directly to the motherboard.
Oct 10, 2013 | Geovision 32 Channel NVR Software License...
S5000 - camera does not display images in 'review' mode - still stays in photo shoot mode
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Dec 24, 2006 | Fuji FinePix S5000 Digital Camera
Sony Cyber-Shot DSC-F505V Digital Camera Logo
77 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
