SOURCE: creda reflection double oven and grill
if fan inside oven starts but no heat, then the probability is that the element is open circuit and needs replacing
SOURCE: Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
SOURCE: Bottom oven not working Tecnik 8525/2
To be certain the element is o/k , you need to test it with a meter.
The fact that it looks o/k proves nothing. If you know how to use a meter, then remove element from oven, and with the meter set on the continuity range, test across the terminals of the heater, if you get fsd, ( full scale deflectoin) then the element should be o/k.
If no deflection , then element is no good.
If in doubt, remove the wires from the element , and try the oven, if it does not trip, then it proves element faulty.
Plz rate my solution.
Thanks.
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
