Question about BenQ MP610 Multimedia Projector
Projector goes through start up twice then shuts down.
When I turn on my BenQ MP721c, it goes through the start sequence (power light flashing green) but bulb does not illuminate. It then does the shut down sequence (power light flashing orange). After that, the 3 lights come on for a second (as if power cord was just plugged in) and it goes through the 2 sequences again (bulb never comes on). Then the power light comes on orange while at the same time the Lamp light comes on Red. Then unit goes back to standby mode (as when normally powered off). The unit was manufactured in March of 2007 and I bought it in May of 2007. Only about half the estimated life hours on the bulb. Is this just a bad bulb? How can you tell if the bulb is bad? I removed the bulb and used an ohm meter to measure the two connections. Could not measure anything (open). Should I be able to measure some resistance across the two bulb connections? Appreciate any reply. Thanks.
  • 142 Answers
The bulb blew out. go to office depot and buy a replacement. this will fix the issue.
Posted on Jan 23, 2009
Hi, I lost password for benq mp720p projector. coded number : 22504-14770-7161-9374
From the manual:
To enter the password recall procedure:
Press and hold Right (arrow)
for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized
user of the projector.
Nov 12, 2016 | BenQ Office Equipment & Supplies
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
BenQ MP610 Multimedia Projector Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
