Question about Grilling
Pieces left over after assembly...
I have two pieces left over after assembly that aren't in the manual... What are they for?
    Novelist:
  • 200 Answers
Not sure which grill you are referring to, but they maybe for attachments or options not ordered, but double check your assembly to make sure.
Posted on Jan 16, 2013
Assembly instructions for Woodcrest F33
Request instructions from Woodcrest.
Jul 16, 2017 | Furniture
Putting the base together
When i put my Fieldcrest Armoire together the base connected fairly easily to the other 3 pieces. Are you sure that you followed the instructions very carefully and haven't mistakenly mixed up some of the wooden pieces? I would re-read the instruction manual very carefully again and if you are sure you've followed the correct steps, you can contact the place where you bought it as maybe they gave you a wrong piece. Good luck.
Sep 29, 2012 | Foremost Fieldcrest Armoire - Espresso
I can't get the shaft to click into place. About 1/2 inch of space between the two pieces.
Are they lined up correctly.? There is a video on youtube which shows the full assembly of this machine, that might help you.
Jun 23, 2012 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Dyson canister won't fit snugly
I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
Best wishes,
Jessica
Jun 22, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
How to change low beam bulbs
If it's anything like my 2002, the whole light assembly clips in. The 'clips' are little tabs on the outside end. They aren't separate pieces, but rather tabs that you can push in with a screwdriver to unclip the headlight unit.
Dec 01, 2011 | 2004 GMC Envoy
I've lost the booklet with the pin code and need to play. How do I get the pin code? This is for Call of Duty 4 Modern Warfare
  • Cheats MenuComplete the indicated task to unlock the given item.
    UnlockableHow to UnlockCheats MenuComplete the game on any difficulty.
    Contributed By: Sour DieseL.
    00
  • Collect All Intel PiecesCheats are unlocked not by inserting passwords, but by acquiring the thirty Intel Pieces strewn throughout the game. The more of them you collect, the more cheats you can access. On the left are the number of Intel Pieces collected, and on the right are the cheats that are unlocked, with an explanation of what each does
    UnlockableHow to Unlock"A Bad Year" Enemies explode into tires when shotCollect 15 intel pieces"Cluster Bombs" One frag grenade thrown equals five in explosionCollect 10 intel pieces"CoD Noir" Play the game in black and whiteCollect 02 intel pieces"Infinite Ammo" Just what it saysCollect 30 intel pieces"Photo-Negative" Game colors become inverteCollect 04 intel pieces"Ragtime Warfare" The game feels like an old silent movieCollect 08 intel pieces"Slow-Mo Ability" Game plays at 40% normal speedCollect 20 intel pieces"Super Contrast" Game's contrast increases.Collect 06 intel pieces
Aug 30, 2011 | Activision Call of Duty 4 Modern Warfare...
HP M3035 ADF has two black plastic pieces that interact with the roller gear assembly. One black piece has a cutout that fits around the blue button that you press to release the roller gear assembly and...
Unfortunately for this model the ADF section isn't broken down into it's individual components,
the part numbers available for the ADF are as follows: (direct from the Service Manual)
Control Panel
CB414-60101
Cover, ADF
CB414-67902
ADF feed roller kit
CB414-67904
Input tray, ADF
CB414-67903
ADF assembly
CB414-67916
Scanner assembly (ADF assembly is not included)
CB414-67905
However your best bet would be to call around to all of your local printer repair shops in your area and asking them if they have any of these M3035's sitting around for spare parts.
Otherwise I could try to find a good picture of the ADF Feed roller kit and see if it contains the parts you're looking for.
Hope this helps! If so please don't forget to leave a positive review for me. :)
Jun 07, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
Renault megane does not appear to have any air in the system but the clutch pedal will not return
check the pressure plate and clutch disc,, you may have a bad assembly and need a new clutch ,, I know thats never a good thing to hear, But in most cases if the pedal stays on the floor and won't return to the upright position, thats the problem,, BUT,,, check the system itself to make sure any other pieces of the assembly aren't loose, Misaligned, or broken (ie, clutch cable, In instances where one is present , or a bad contact point for the throw out bearing arm )
May 14, 2011 | 2006 Renault Le Car
Grilling Logo
20 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
