Replacement port The charging port doesn't work. When trying to charge the tablet using the USB cable, the charge doesn't hold. Where can I get this fixed?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Try another cord before you take it to anyone
Posted on Jan 13, 2013
osborne382
  • 306 Answers
SOURCE: Laptop will not hold charge
more then the battery was harmed during the melt down.. its going to need to go to the shop for repairs
Posted on Nov 12, 2007
SOURCE: mouse touchpad, keyboard, and usb drives will not work
i just removed the battery. it works too.
Posted on May 06, 2008
Rajan Solank
  • 62 Answers
SOURCE: i am unable to charge my laptop due to the charging port
please explain what is wrong with the charging port. it may be a problem with your adaptor instead.
Posted on Jun 07, 2009
dilum_wonder
  • 59 Answers
SOURCE: My mobile won't charge from USB port
in your laptop goto device manager. universal serial bus controller. go to appropriate port. Right click- properties - there you will c a power management tab. uncheck Allow the computer to turn off this device to save power. click ok.
Posted on Jul 20, 2009
  • 17 Answers
SOURCE: My Toshiba's laptop's sleep and charge USB port
It's possible to fix. First go to device manager and you should see something like "USB Root Hub". Double click to open it, go over to power management, and "Uncheck" "Allow this computer to turn off this device to save power". Do this for all that say USB Root Hub. Next go to "Power Options" then "Edit Plan Settings" (accessible through "choose when to put the computer to sleep") and select "Change Advanced Power Settings". Next, make sure you do this in all of your power settings, but scroll down to an icon called USB settings. Expand the selection, then expand the "USB selective suspend setting". Choose, both on battery and plugged in if you want, to Disable the selective suspend. Finish and apply. Also, to confirm, you know that the USB device (IPod) but be plugged into the eSATA port, correct? It doubles as a USB port and is the only one capable of charging.
Posted on Jul 15, 2010
Why won't my 10.1 tablet charge?
Hello Pauline,
I know this must be frustrating. When this occurs, it is more times then not a problem with the hardware power port on the tablet. (the hole you plug the USB cable into on the tablet)/ The USB cable cannot make a solid connection because the port is damaged, and therefore electricity cannot get to the device or battery.
Do you have a warranty? I recommend seeing if the manufacturer will replace it. Also, if you have device insurance, you can try and get a replacement. Either way, you must replace the broken hardware power port.
May 25, 2015 | Hannspree HannsPad SN10T1
Tip
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 | Amazon Kindle Fire HD
Tablet wont charge
you most likely need a new charging port,,,, they are available on amazon, just search for #### charging port , , #### being your model number,,,, or remove the back number and read the number on the harness for the charging port and amazon search that number,
you tube videos will show you how to replace that, if you watch the vid for replacing the screen, you will see the charging port being removed and you'll then know how to do it
Mar 31, 2015 | Tablets & eReaders
How do I get my tablet to turn on
It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Mar 29, 2015 | Lenovo S5000 7" Android 1GB 16GB
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
Vizio tablet won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 28, 2012 | Vizio Tablet VTAB1008
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
How do I charge my Verizon Motorola Droid using the USB cable and my computer. I've plugged it into my computer, but it doesn't show that it's charging.
Plugging it into your computer should be no different then using a charger...it still uses the USB cable.
Here are a few things to check...
do not try a USB port that is off your keyborad or anything that does not come straight off of the motherboard...the phone pulls too much power and it will not work...
Try a different USB cable... some will not allow charging but will still tranfer data...
Also check and see if it asks you to install drivers for your phone...if it does, you will need to have them installed to charge the phone...
My best guess is that you need a different cable...
heatman101
May 12, 2011 | Cell Phones
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
