Question about Kenmore KCP12PRO Coffee Maker
Krups model 467
Continuous flashing light on right side. What does it mean?
Means it's time to buy a new machine. This one is worn out, and past its expiry date.
Posted on Nov 24, 2007
SOURCE:
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 28, 2014 | Whirlpool Refrigerators
Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Feb 22, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Not sure how to take it off cleaning mode. The cleaning button continues to flash?
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u will need adobe to open it
Jan 20, 2009 | Krups Super Automatic XP 9000 Espresso...
Krups 467 turns itself off after one hour...
The auto off is configurable as I recall. I don't think you can fully hobble. Coffee kept hot much longer goes bad despite the prolonging powers of the Krups. RTFM online and you should be able to learn the menu command sequence to configure it as you like subject to whatever it allows.
Jan 18, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Red blinking light on krups coffee maker
It means your water filter needs to be replaced. I wouldn't know this either as I found my coffee maker in a thrift shop, but I read it on Epinions a few minutes ago in a review.
Have you had any problems with splashing when brewing - some of the water missing the spout? I lose up to a cup of water and I'm stumped. The goldtone filter has to be pushed to go down into the unit, does this mean I'm putting it too far in and screwing up the stop n pour or something?
Jan 02, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Kenmore KCP12PRO Coffee Maker Logo
196 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Jude24
gbob59
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
