Question about HP OfficeJet 6210 All-In-One InkJet Printer
Vertical lines on printed, copied or in-coming fax
When I print, receive faxes or copy a b+w document, long vertical lines appear on the copy. i have cleaned the flatbed glass with windex and also the inside of the cover, but I still have vertical lines. Any idea what the problem is?
    Scholar:
  • 97 Answers
Since u have cleaned the flatbed and inside the cover,thats a nice move thou. Try the following steps that should resolve the issue,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 23, 2009
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Streaks on faxes and copies but not on printed documents
Clean the glasses on top!!! Your CORONA lens is dirty!!! it must have some cleaning brush or bar near the side!!!
Jan 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
