Can u use 10-2 elect.wire to hook up power inverter in a car
    Scholar:
  • 155 Answers
Size 10 wire is pretty big - it will probably be too hard to use. How many amps do you plan to use? The #10 wire is good for 30 amps - that's usually more than what a normal house's outlet can carry. #14 wire can carry 15 amps.
Posted on Jan 16, 2013
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
What size wire need to used for hook up elect 7hp 60 gallon g5396
Hi GCHEVY,
CH recommends their power cord part# EC012902AV. This is a three wire cord, using 10 gauge wires. (1) Black, (1) White, (1) Green or Bare. See CH video here for additional setup tips:
http://www.youtube.com/watch?v=iWtNdr_-7Iw&feature=player_profilepage
The wiring instructions are toward the end.
Bruce
Jun 26, 2011 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
I need help hooking my vector maxx sst 1000 w power inverter to my car
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
Jul 20, 2010 | Vector 1000w Power Inverter
I have 5000W inverter & hooked up to my battery power supply.display is saying "l up" .i think it means lock up.i was wondering how to unlock.
Could it be L.U.P. it's really L.V.P. but the V looks like a U. If it is it's low voltage protection. If the incoming voltage drops below 10.5 volts, it begins to flash. If the voltage drops below 10 volts it shouts down. If you supply it with 12 v it should restart. If you don't have manual you can view/download one from www.cobra.com.
The low voltage could caused by low battery. Poor connetions. Wire too small for load being supplied.Inverters over 1500 watts will require #1/0 or larger cable, in the shortest possible length. NOTE: Cable size recommendations may vary among inverter brands and models; check the Owner's Manual for the model you purchase before you buy the wire for it.
Jun 21, 2010 | Cobra 2500w Power Inverter
Do not know cubic size. It is a side by side approx 10 years. Motor is running but coil is freezing up in freezer, refrig side is not cooling. Evaporator fan not running so changed evaprorator motor. Fan...
The problem is still from the fan, try to settle down and try to connect the wire properly. if the wire is fix properly fan will work and refrigerator will also work.
Goodluck
Jun 28, 2010 | Amana SXD524VW Side by Side Refrigerator
What do elect.start wires hook to on 80s 5 horse
maybe there are for the Switch? to the solenoid, that engages the contacts to switch through to the starter. Usually it goes from the battery, to a solenoid, that breaks the Power to - from the battery to the actual "Starter motor". try to "Trace" them out and see where they go. just a thought?
Mar 07, 2010 | Troy-Bilt Pony Garden Tiller
Hooking up elect. brake system to 1995 siverado
hoppy makes a direct plug in kit, spend the xtra and save the headache
Dec 12, 2009 | 1999 Chevrolet Silverado 1500
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
No power output from my vector 1000w inverter.
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
