Question about MSI Computers & Internet
I went out from my room just 5 minutes and after I came back I saw an error message on the screen, a big one on a dark blue background but I didn t have time to read it, I just saw the word error after 3 other words then my laptop started to make a weird noise like... Beeping and the screen turned black and started to flash from black to a lighter black. I have turned it off and on few times after that but... nothing! This never happend before and I didn't install any suspicious software recentely. I have this laptop since 2009 december. Is an msi with windows7 32bit. Please help! I need my laptop like I need air! Nowadays school(teachers) force you to have even a facebook account. Seriously! However... I have so many school projects and homeworks and as I said... I really need my laptop.
    Sergeant:
  • 251 Answers
I think it is your RAM chip. If you have 2 RAM chips put the one from the second bank and put it in the first and see if it boots up. RAM is pretty cheap now anyhow.
Posted on Jan 13, 2013
nipperthedog
  • 13 Answers
SOURCE: LAPTOP WONT BOOT/START
To go through the recovery program I think you tap the F11 button as you start up. Press the power button and keep tapping F11 until the recovery program starts. I have restored my easynote L4 back to factory settings twice with this utility.
However, I get the impression you have already done this and you are experiencing what's known as the Blue Screen Of Death BSOD. Don't let this term frighten you, it doesn't mean the laptop is fried. My laptop only came with 250mb of ram, so I upgraded and installed another stick in the spare port. Had you installed any more ram yourself? As postmanfw says...need to know what was happening before you tried to restore back to factory settings.
Posted on Jan 06, 2008
SOURCE: MY inspiron 1150 won't power on
there is a problem with your memory. TURN OFF THE LAPTOP turn the laptop screen side down there are two areas you can open. open the one more to the centre remove one or all memory module inside replace with new memory module. or if there are two memory modules in take one out then turn the laptop on if it does not start take the other out, put in the one you took out first back in start the laptop if none works by themselves you need new memory
thats the solution REMEMBER TO RATE THE SOLUTION THANKS
Posted on Apr 09, 2008
Pyrhyc
  • 2028 Answers
SOURCE: help on my fujitso siemens MS2212 please...
The clicking is from the hard drive. This clicking , along with the error op system not found, indicates that the drive has crashed or failed. You will have to replace the hard drive.
Posted on Jun 25, 2008
  • 14 Answers
SOURCE: Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Posted on Apr 18, 2009
SOURCE: laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Posted on Jan 05, 2010
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Was playing Super Smash Brothers, played 1 5 stock 1v1v1v1 against 3 computers, then went and started a second round. It lasted for about a minute or 2 and then it locked up... i hit the reset button, and...
Well I think that the expansion pack has died I had a problem while I was in the middle of perfect dark it would freeze and then 2 seconds later the screen went black and than it went to the tv screen saying no signal. the expansion packs make it look like it died but it didn't.
Nov 01, 2010 | Nintendo 64 Console
Samsung Tocco Lite says ''download'' on blank screen
I turned it off, then took the battery out for 5 minutes then put in back in and turned it back on, this should work, however for me it didn't so i turned it off and on again on doing this it went to the normal loading screen
Jan 27, 2010 | Samsung Tocco Ultra Cell Phone
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
My Samsung HLN5065W started to freeze to a black and white
I have a problem with my HLN 5065W Samsung DLP that 3 other folks have and no solution. After the set is on from 5 minutes to 6 hours, the screen will freeze in black and white, I can turn it off for 5 minutes and it will display a good picture again. Sometimes the screen will just go dark blue, TV has to be cycled on/off to get the display back. This problem is getting worse, started as once a month, now 3-5 times a day. I have a tech background and can read a schematic, HELP.
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
Dark background blue tint
Try the Magic Focus option on the menu screen found under "Picture". Make sure the TV is on for 20 minutes before activating this option. It is also best to run this when the room is dark.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Blue screen
NEVER BUY SONY AGAIN. WE HAVE SAME TV, NOT EVEN 2 YEARS OLD, AND IT IS IN MY DINING ROOM TAKING UP SPACE AND COLLECTING DUST WHILE WE WATCH OUR NEW BIG SCREEN IN LIVING ROOM....KP-WS57500 IS A FAULTY TV AND SONY SHOULD GIVE EVERYONE THEIR MONEY BACK. THATS WHY YOU CANT BUY THE LIGHTS FOR THEM, CAUSE THEY ARE NO GOOD SO SONY DISCONTINUED THEM. SONY SUCKS
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Computers & Internet Logo
46 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
