Question about Hitachi 50V500 50 in. HD-Ready LCD Television
TV does not turn on
I have a Hitachi flat screen, and the Over Temp LED in front of the TV is Blinking
Needs a new power supply board
Posted on Jan 23, 2009
Hitachi TV LED screen went black
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 12, 2016 | Hitachi Televison & Video
Tv will not turn on after being left on standby
capacitor wearing out on 5v side of the power board, this or these will need changing look for the tops of the capacitors blown up or leaking brown stuff around them and change them for same type ie 10v 487uf dont buy blue type they only 85c temp rating buy 105c rating.
Mar 30, 2015 | RCA Hitachi Le22s314 22" Led 1080p Full...
I have a 42 hitachi lcd tv when turning on the tv the led light comes on and off a number of times then stays on and the screen lights up then it's ok just getting it going is the issue can you give me a...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 12, 2015 | Hitachi Televison & Video
Hitachi tv won't turn on, only flashing orange and blue light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 27, 2014 | Hitachi Televison & Video
Hitachi tv won't turn on. Model 40HXC06U. The red liht is blinking in turns with blue light - thats how tv turn on but when screen should show hitachi logo lights stop blinking and tv is still on stand by.
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
