Question about Onkyo Dx-7355B Cd Player - Black
Dx7355 locked good morning my cd player is "locked" it will not open the drawer to change a cd. when I press the "eject" button, "locked`` appears on the display and it will not open.
    New Friend:
Set your Player back to Factorysettings. Push "Skip forward" and "Repeat" at the same time. "Clear" appears on your display.......now you should be able to open your deck.
Posted on Jan 27, 2013
There is a cd in the drawer and it plays great. But i cant get the drawer to open to change it
You may have a load / eject motor issue.
That being said there should be a pinhole to eject the CD. Straight out a paper clip and insert into the hole and press the manual eject button
May 06, 2016 | Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
CD drawer will not open
This is most commonly a belt in the drawer mechanism and is easy to fix IF you have the right belt in hand and can access where it goes.
A technician will be able to help.
Dec 08, 2012 | Audio Players & Recorders
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
The drawer that holds the cd's will not open. Where the cd screen is it changes to def.
Most DVD players come with an emergency eject option. First turn the player of for a while and then try ejecting again. If it still doesn't eject press and hold the eject button for 5-10 seconds. This will force the eject motor for about 5 seconds. If everything fails your Player's CD tray assembly (could be a faulty motor or the plastic support on which the tray slides is worn out). You will need to get the tray assembly replaced.
Let me know if you need more help.
Sai.
Dec 16, 2009 | Audio Players & Recorders
CD is jammed in drawer of Philips MC-70 Mini Shelf System. Cannot open or play. How can I open drawer and extract CD?
look at the drawer is there a small hole on it? if so use a paper clip on that hole to eject the tray.
try unpluging it for few minutes and try again.
Mar 15, 2009 | Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
Problem with stereo playing cds
I'd be interested to know the brand, but you could try this:
(Assuming your CD player has only a standby button, not a full On/off button). Unplug the CD player from the mains. Leave for 30 seconds. Connect to mains and press eject as early as possible. Hopefully, this will allow the system to eject the CD before it starts trying to spin it.
Ultimately though, if it plays but won't open, it's likely to be a cog / gear on the drawer that has failed rather than some software fault as the CD plays.
Repair may not really be economical - depends on brand / value etc. If the disc is more important than the player you might end up attacking it....
Jan 15, 2008 | Audio Players & Recorders
DVD door won't open
try using a knife without the dvd player plugged in that will get out the cd
Sep 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Onkyo Dx-7355B Cd Player - Black Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
