Question about LG Panorama 20.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
GWP227Y Switch off when the door is open and out of operation next.
Type of refrigerator: LG GWP227YTNA - Side-by- Side type Other observation: The bulb (40W) flashed and burnt-out at door-open. The fridge doesn't work neither after repllacement of bulb. Thanks foryour help in advace, BR Lajos
  • 489 Answers
SOURCE: Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Posted on Jun 11, 2008
I had the same problem and fixed it by replacing the Main PC board mounted on the rear of of the refirgerator, as rstynls pointed out. Part number is 6871JB1423N, available from Sears parts direct for around $100. I see it's also on eBay for about $80.
Naturally you want to replace any melted parts like the lens shround and cover if needed, but I didn't replace the socket assembly or reflector even the socket assembly was slightly discolored. I don't see how a new socket assembly could incorporate a temperature sensor since that would require there being a wire run for it already in place, unless the original units had the wire there but it just wasn't used. Even so, if you have to rely on the temperature sensor to shut off the light, you have a problem to fix anyway, although in theory it may prevent a fire hazard.
Posted on Dec 09, 2008
MNTECH
  • 1543 Answers
SOURCE: inside of door when you open lg refrigerator is very hot
I suspect you are talking about the area between the doors. Refrigerators use a loop off the compressor to warm this area to prevent condensation from forming there. Older refrigerators sometimes used an electric heater there, but of course that increases energy consumption. You will notice that the area is much warmer when the compressor is running. All this is normal, and saving you energy.
Posted on May 26, 2009
  • 112 Answers
SOURCE: Dents in fridge door
Contact an automotive "paintless dent removal" provider-- they are mobile, so they can come to your home.
Posted on Jul 09, 2009
omaharox
  • 165 Answers
SOURCE: How do I open the plastic shield covering the
Use a butter knife and insert it in the slot between the cover and white plastic holder and pull the knife lightly twords you.
Do this on both sides and the cover should come out.
Use 40W bulbs for replacement.
Posted on Jan 17, 2010
Dispenser not working
With the door open that motor is not supposed to operate. This coulod be sesveral things. One of them is the switch on the door and the other is the wire harness from the door to the unit itself.
Aug 25, 2013 | LG LSC27910 (265 cu ft) Side by Side...
No ice
First check to see if the ice maker is operating. you can take the face plate off and observe if the gears are turning. The next thing to check is the water solenoid. This operates after the ice maker rotates to a certain degree, pushing on a micro switch that sends power to the solenoid (valve) that opens and allows water to flow into the ice maker basin If this solenoid is working you will hear a loud click. Next, check to see if the water in the inflow pipe is not frozen, by disconnecting the refrigerator AC power. Get a hair dryer and play the heat output onto a small plastic pipe that dumps into the back of the ice maker. This pipe sometimes becomes frozen with water ice and will not allow the water to flow into the ice maker. Mine has done this twice over the 12 tears I have had the refrigerator.
Dec 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I can hear a beep every once and awhile. When I open the frig, sometimes the light is out, but the refrigerator is operating. I changed the filter and nothing else seems to be wrong.
Is this a door alarm? ARe you sure the temperatures are good? or are they sort of ok, indicating it is getting warmer. the filter is only for the ice maker and the water dispenser.
Dec 10, 2010 | KitchenAid KSCS25FKSS Side by Side...
My Whirlpool Gold side by side refrigerator when you open the refrigerator door you hear the sound of maybe a relay trying to open and shut. The display panel that shows the thermostat setting is off and...
sounds like your having an issue with your door switch its just not opening the machine still thins the door is closed
that clicking you hear could either be the switch itself arcing inside
not knowing your model number i cannot be sure
but that is ehre id start
www.appliancepartspros.com
type in your model
the door switch should be in the body/cabinet section
Oct 26, 2009 | Refrigerators
Interior light bulbs stay on?
There is a switch on the inside of your frige that has gone bad. The switch is a slide type switch so when you open or close the door it makes the switch slide in and out, making the light come on and off. You need to write down the make and model # of your refrigerator and order a new switch either from the manufacturer or from the place you bought it. Once you have the new switch, unplug the refrigerator, take a flat head screw driver and gently pry the switch from the interior face, pull the two wires off and replace the old switch with the new. The switch is very inexpensive and very easy to replace. Calling a service technician out to do this could cost you more than you expect. If you are not very "mechanicaly enclinded" then just order the switch and have a brother, neihbor, or someone that is mechanicaly savy come over and fix it for you. It should not even take 5 minutes. ;-)
Aug 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Bottom freezer door opens when top door is open and then closed
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
Jul 02, 2009 | Refrigerators
Water/Ice Dispensor Malfunction
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure the refrigerator has the blower problem for which the problem arrises ....... please visit your service authority...........have a nice day:-)
Mar 02, 2009 | LG LRSC26920TT Side by Side Refrigerator
Refrigerator Door Reversal
you can switch most makes without extra hardware
Aug 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
LG Panorama 20.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
26 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
