Question about Refrigerators
How to defrost the freezer compartment of my KIC super cool fridge/freezer
The fridge compartment is self defrosting but there seems to be no way of defrosting the freezer compartment
watugot
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
Illeagle
  • 525 Answers
SOURCE: proline pc178a fridge freezer still
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
SOURCE: Lec Elan Fridge Freezer: Freezer
Check freezer door seal
Regards, Barry
Posted on Feb 26, 2009
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
  • 358 Answers
SOURCE: Cant find defrost swicth on NEC fridge freezer
The defrost timer should be inside the refrigerator where the cold control is.
Posted on Apr 23, 2009
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Crystal cold lpg fridge the fridge part works fine but the freezer only cools to the same temp as the fride compartment
The freezer should go down to about zero degrees. If your unit is constantly running it is because the internal temp has not activated the thermostat to turn off the compressor. Lower than normal refrigerant levels could account for this. Also to be checked out is the evaporator coil not being frozen over with a block of ice - the latter is caused by an inoperable self defroster - this causes the freezer to not cool properly and raise all internal temps.
If not a self defrosting unit, defrost the unit and restart unit. It will cool properly until the evaporator freezes up again. How fast it freezes up depends on how often the freezer door is opened and how much moist warm air enters the freezer compartment.
Nov 21, 2013 | Refrigerators
Fisher & Paykel E521T Fridge Ice Build up behind Freezer compartment. I have had my fridge for about 7 years and ever since I bought this fridge I have to defrost it every 6-8 months because water...
Have they cleaned the drain tube that runs down the back of the fridge? If not and the tube is clogged water will back up and give you the problem that you are having. The only other thing that I can think of, is that the defrost cycle may not be set to a minimum amount of time to where this can be increased to allow the freezer not to let the ice build up.
Apr 19, 2017 | Fisher and Paykel Active Smart E522B...
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Freezer seems to be working properly, but fridge cant keep temp
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Mar 25, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
Fridge don't work after defrosting session
It depends on weather or not you damaged it during the defrost. Most fridges' are self defrosting. Look at the coils behind the back cover inside the freezer. They should be covered in a light frost if the compressor is working right. Or Is the fan in the freezer running. It has to blow the cold air around the freezer and to the fridge side. It may cut off when the door is open so hold the door switch in to check. The humming in the freezer could be the fan trying to run but can't because of a defective fan or being blocked by somthing.
Sep 02, 2009 | Candy CPCA270FFK Bottom Freezer...
Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Jul 15, 2009 | Refrigerators
Firdge not cold on a combi fridge freezer
possible ice build-up behind the inside rear panel. you have to remoive panel defrost ice with hair dryer then replace the heater/defrost cable. the job cost around 125. for an appliance tech to fix it hope this helps...
Sep 22, 2008 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
