Question about Kitchen Ranges
Modern maid 550 gasomatic stove/oven
My problem is with a modern maid gas stove/oven but I suspect this is not the place
2 Suggested Answers
SOURCE: modern maid double built in oven. gas stove. pilot
it"s a built in range top, and started making clicking noises randomly
Posted on Oct 17, 2010
Oven igniter comes on gas burner lights but goes out after 15 seconds cutting power to the stove power comes back on after a couple of minutes model mgs5770
Hello Susan,
it is not quite clear to me what you mean.
But I think, the ingition in the gas oven works and lights the burner.
and then after 15 seconds the burner goes out.
Any modern oven has a Flame Failure Device.
That prevents the oven getting gas when the burner went out for some reason.
I would suspect that FFD, it is mounted besides the burner.
You can not repair that part for safety reasons, You have to replace it when it is gone.
Kind regards, Dik
Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
Feb 10, 2018 | Kitchen Ranges
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Oven button will not engage
Remove the knob/button and look inside if it is split it won't grip the shaft and needs replacing.
Apr 15, 2014 | Amana Modern Maid Downdraft Stove With...
Trying to bypass electrical ignition on oven to
Hi, the gas valves on modern ovens are electrical and cannot be turned on without electricity. Only the cook top burners can be lit manually.
Jan 29, 2010 | Tappan Kitchen Ranges
Modern maid double built in oven. gas stove. pilot light won't stay lit
Dec 13, 2009 | Tappan TGF657 Gas Kitchen Range
I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Jul 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
