Hardware change audio,keyboard and mouse are not working
  • 7,627 Answers
Have you Done a OS upgrade?
Posted on Jan 14, 2013
Hardware changes
Have you done a OS upgrade?
Jan 13, 2013 | HP PC Desktop
I do not believe my mouse is connected to the device. I turn on my desktop and the mouse and keyboard do not work, so I cannot even enter my password to log onto the desktop.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
hope this helps
Feb 01, 2011 | Microsoft Standard Wireless Optical Mouse
Mx3200. Keyboard works. Mouse doesn't
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Jan 04, 2011 | Logitech Cordless Desktop MX3200 Laser...
My keyboard neither mouse are not connecting my computer it just doesnt show up i have a remote that connects to the same usb sender perfectly fine but the mouse and keyboard wont. Thank you,
its hardware problem, may be water or any liquid get inside and make the keyboard not work state, do you have any function key to disable keyboard or mouse mean go to control panel -> hardware setting check whether mouse was disable or not, if it disable mean make it enable so that your mouse works good same for keyboard.
Good luck
Dec 30, 2010 | Acer NSK8458AN Keyboard
MY KEYBOARD AND MOUSE HAVE BOTH STOPPED WORKING. I HAVE THE KENSINGTON PILOTBOARD LASER DESKTOP SET. # 64390. I HAVE PLUGGED IN A WIRED SET BUT I MISS MY WIRELESS !!!! CAN YOU HELP ME? I HAVE CHANGED THE...
If the power cells are new, both the keyboard and mouse are powered correctly (Battery I assume are positioned correctly). If Neither one operates, then check the small dongle that fits into the USB port. It may have been loosened, and if so just pull it from the port and reinsert it in another port. If still no connection, then the dongle may have burned out. The problem: Once a dongle is spent, the entire set is useless as they operated on an audio signal (Frequency) set for that mouse/keyboard. No replacements.
Jan 31, 2018 | ACCO Brands Kensington PilotBoard 64390...
It does not work
Usually for the combo mouse and keyboard you need to install a driver for that... try checking the manufacturer's website for combos
Mar 27, 2010 | Computers & Internet
Just changed batteries in my wireless mouse.
there will be a button on your mouse. Press it to sync the settings with your laptop and it should start to work.
or else
click start
right click my computer
properties
hardware
device manager
?mouse and keyboard
scan for hardware changes
Feb 26, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse and keyboard installation problem
click start
properties
hardware
device manager
?mouse and keyboard
Aug 23, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Audio Problems
see if the drivers are loaded correctlly, uninstall the audio device and scan for hardware change, see if installs properlly next time
Mar 19, 2008 | HP Combo Case HP PAVILION Speakers, Mouse,...
Computer not recognizing Keyboard, only Mouse
I'm having the same problem. Mouse works great but the keyboard doesn't. I've uninstalled and reinstalled the software at least twice via remote desktop- done a hard reboot on the hardware (it's a Logitec wireless keyboard) - I've even tried installing it on another computer and the keyboard and mouse both work great! I just can't get it to work on my computer. The curious thing is that the side buttons (like sleep work) but it won't Ctrl Alt Del so I can login - what am I doing wrong? Are there settings that need to be changed?
Aug 17, 2007 | Sakar 62150 Keyboard
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
