Question about HP Computers & Internet
Application error/exceptioneoserror in module rt170'bpl at ooo1823a
Compute shuts down, when i try to restart an error fix window comes up on screen saying it is trying to fix problem. this has happened many times.
    Sergeant:
  • HP Expert
  • 427 Answers
Reinstall windows.
Posted on Apr 17, 2013
Hollyecho
  • 313 Answers
SOURCE: computer froze
Yes, it does. Try this:
How to Repair Install: ***Also removes Service Packs***
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP.
There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade. Create a Slipstream version to solve this problem
If you cannot boot to the Desktop, or you have an OEM version of XP, or you want to remove a service pack then the following should be used to complete a Repair Install.
Boot with the Windows XP CD and at the Setup Screen press the Enter Key
You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed.
setup02.jpg The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
setup03.jpg Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
setup05.jpg rc%20017.jpg setup06.jpg When Setup has completed you should find all of your previously installed apps and settings are intact.
Posted on Jul 17, 2008
SOURCE: Wireless WLAN
I have been working with Dell on this problem for quite some time. They tried replacing drivers, uninstalling and re-installing the card, replacing the card with a new one, etc, etc. Nothing worked. Sooner or later the error came back. Their last "fix" was to suggest that I restore the system to factory default condition and start all over again. I refused to do this. I had spent over 8 months adding software, tweaking it and windows, etc. They basically threw up their hands and gave up.
The Dell tech who replaced the card tried the solution noted here and "supposedly" it was fixed. A few weeks later the error came back.
So... I still don't have a fix for this problem.
If anyone finds one please let me know.
I'll check back here periodically.
Thanx,
Randy
Posted on Sep 19, 2008
  • 177 Answers
SOURCE: My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Posted on Nov 24, 2008
rickyostrom
  • 274 Answers
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Posted on Nov 30, 2008
ebay312
  • 118 Answers
SOURCE: Black Screen Error, Windows Vista Dosenot Boot
You have a complicated issue that is very difficult to repair using this one way conversation method. I must, however, compliment the detail of your description.
From what I can see, you have a problem with one of two, or possibly two of two things. One message says your network card is not functioning properly, the other says your hard drive is not functioning properly.
Either of these issues may be either the device which has failed or the software which controls it has failed.
If you have access to another machine, you may be able to remove the hard drive and test it (this would be my first choice, since a recovery disk should still work even if the Network card does not).
By testing the harddrive, you can be sure it is working properly. If it is working properly, the next test would be on the memory. Believe it or not, memory often will stop a system from reading data off the DVD drive during recovery or installation of the operating system.
This one would be much easier for me to help you diagnose if I had it in my possession, and I'm certain most techs will tell you the same thing.
Additionally, the recovery disk may actually be bad, and this can be investigated with a visual inspection. Look for scratches and fingerprints on the disk.
And often, Windows Vista does not install unless the BIOS is set to the INSTALL OS mode. Different machines do this differently; and again, if you had another machine that was working, it would help.
Good luck.
Posted on May 17, 2009
Snooper Truckmate pro Sound DB8500: error asimap.exe
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Snooper Application Error Asimap.exe) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Mar 20, 2016 | GPS
Problem signature: Problem Event Name: APPCRASH Application Name: integrator.exe Application Version: 12.0.2110.8 Application Timestamp: 4ec65a41 Fault Module Name: MainControls.bpl Fault
If this is causing you to have crashes, the .exe is probably corrupt. It belongs to booster and certain tuneup utility programs ("Dachshund Integrator or TuneUp Utilities (version 2006, 2009) or Glary Utilities (version 3) or Glary Utilities PRO or Auslogics BoostSpeed"). If you have any of these programs installed I'd uninstall it and restart your computer. Then reinstall if you want to use the program still, though preferably after an update. I'd also clean your computer with CCleaner and remove junk files before reinstalling. This will clear corrupted files that might not have been removed with the uninstallation of the program. If you continue to experience this issue, install sandbox and make sure the program runs within sandbox. This will prevent any faults or issues with the program from interfering with your OS.
Sep 07, 2014 | Microsoft Windows Vista Home Premium with...
Satellite PSAGCA-06M01N keeps restarting when i try to upgrade windows
Computer randomly restarts is not something unique happened to you. Sometimes there is a dreadful total crash of the system and sometime it sends different errors, upon restarting nothing happens.
-- First of all disable the auto-restart option from your control panel settings
-- Remove any recently installed maliciously software/add-on or any other application or toolbar.
-- Try to cool down your PC as the overheating due to overuse of computer may result in system freezing and sudden restarting.
-- Update your BIOS.
-- Update the drivers
-- Make it sure the error is not caused by the deficient power supply. You may try to change the power supply.
-- Conduct the registry clean up scan for quick fix of the problem.
-- Remove flashy games and/or untrusted antiviruses/antispywares. Conduct the security scan through the most powerful scanners only.
I would recommend to use a system utility tool like PCFresher to fix windows errors and registry errors. Then try updating hope problem is fixed.
Apr 29, 2012 | Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Rtl100.bpl not found free
Hello Estherc54,
If you got rtl100.bpl error then there are chances that your computer has registry problems. To repair rtl100.bpl error you need to follow the steps below:
  • Step 1 - Choose a rtl100.bpl error repair tool,download and install rtl100.bpl error repair tool Scan for FREE.
  • Step 2 - Click the Scan Button.
  • Step 3 - then click the Fix Button and your done! It is very easy to repair rtl100.bpl error.
  • URL : http://www.fixerrorfast.com/ttfix-rtl100.bpl_error-zz0001
    Best tools : Regcure, Perfect Optimizer
    Regards,
    soul_srch007
    Dec 05, 2009 | Microsoft Windows XP Home Edition
    Internet explorer will not open. Error message below.
    Okay, the driver for IE (hal.dll) needs to be reinstalled.
    Do the following:
    Press the windows key and R
    Type in command
    In the command prompt that comes up:
    Type in cd C:\Windows\System32\
    Type in taskkill /f /im "hal.dll"
    Type in del hal.dll
    Then restart your computer
    What taskkill does is kill the IE application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the IE driver, and the problem will be fixed!
    Mar 12, 2009 | Dell Vostro 1500 Notebook
    Application rtl100.bpl
    Hello!!
    Insert ur XP cd and boot it thro the cd and enter the repair console and try FIXBOOT command .. or try the other method .. run msconfig .. and disable the error in startup menu .. thanks for using fixya!!
    Feb 23, 2009 | Dell Microsoft Windows XP Home Edition
    Computers & Internet Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
