Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore side by side 596.58642891
Our freezer side is not working again. We had it worked on 6 months ago, and the repair man said this is typical of this model. I can't find the paperwork to get the part info, so we can order it and do it our selves. Can you see what the common problem is for this model? Thanks, Diane
Sea Breeze
  • 4655 Answers
SOURCE: side by side frig side stops working freezer still works
The best way to solve this is to email me the models number found near bottom of the fresh food compartment door. Sears problems are difficult to solve. Fixya changed their way of solving problems and posted the people to call just below your link. The email address for me is appliancepartsse@yahoo.com. I know I can solve the problem and have been here at Fixya for 3 years and have done well until now because they change the ways I can tell you how to find and fix the problem. Good Luck and hope to hear from you, Sea Breeze the model numbers for Sears look like this 213.547895
Posted on Jun 08, 2009
WALNUTS420
  • 3 Answers
SOURCE: Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Posted on Aug 12, 2009
Testimonial: "Seems this comfirms what I am hearing. sounds like I should change the thermostate and go from there. Thank you. "
  • 403 Answers
SOURCE: Kenmore refrigerator stopped cooling 6 days ago
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Posted on Sep 26, 2009
Testimonial: "Thanks so much for the fast response.I will try these solutions and get back with you."
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Elite Model # 106.566.82501 Side by
Depending on the age of your refrigerator and cost of replacement parts I think right now would be a good time to decide what you will do. I have a feeling that the problem is related to the main control board inside the fresh food compartment, part number 2313180. It's over priced and if you need to pay someone to put it in I believe you could buy a less expensive refrigerator without electronics and have just a simple defrost timer and it would last longer. My answer is not a fix it's bad news that anyone would put a price on a part like that and expect the consumers to be happy about it, Sea Breeze
Posted on Dec 22, 2009
Testimonial: "Thank you very much for the information and the quick response. I will check into the price of part and determine wether to go forward with repair."
  • 1218 Answers
SOURCE: Kenmore Side by Side not cooling. New ADC board.
Good day,
It is possible the defrost control failed. If so, it would still be in warranty.
However, the most common part to fail, is the defrost thermostat which is located behind the rear panel, in the freezer compartment.
It is a small round disc about 1" in diameter, mounted to the top of the cooling coil.
It can be tested, with an ohm meter, but must be tested before it can warm to above 30 degrees. It should read zero ohms of resistance.
Rarely, as well, the main heater which is mounted to the bottom of the coil can fail. It's a calrod unit somewhat like the bake element of an electric range. Unplug it, and check the continuity with an ohm meter. It should test out in the 25 to 50 ohms range.
If both check O.K. then the timer has failed, and needs replaced.
Thank you for using FixYa
Posted on Jan 25, 2010
Stuff in freezer is thawing. Outside edge of freezer and center divider between refrigerator and freezer getting very hot to the touch. This comes and goes.
this refrigerator had slow leak. last time 6 month ago, another tech from our company was there and charged refrigerator with freon and leak dye. now i found leak dye with special light in the drain pan, spayed with soap - bubbles come out. Replaced that drain high side line. Hope that helps.
Feb 09, 2015 | Refrigerators
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a Kenmore white side by side refrigerator Model# 106-56542400. The ice maker is not working we already replaced the filter a week ago and it is still not making any ice at all. On the left side when...
Up on the top right hand corner of your freezer, next to where the ice drops, there is a small black tube. That tube freezes and it will stop the ice maker from working. Take a blow dryer to it until you see the tube without the ice hanging from it. you will have to do this about once every 6 months. After paying for a repair man to come out and fix it, this is what he told me to do. Good luck.
Oct 22, 2010 | Kenmore Refrigerators
Kenmore side by side refrigerator 58642891
depends on the AGE of the one you have needing repairs . FIXYA can not determine what you need to do .
Nov 14, 2017 | Kenmore 56563 Side by Side Refrigerator
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice build up on back wall of freezer
You need to replace the heating elements and defrost timer relay. Had same thing as you 6 months ago. The lower one is probaly blown but replace all 3 parts or youll continue to have problems.
Jun 11, 2009 | Kenmore 53642 / 53644 Side by Side...
I have a Ge PSW26LSRDSS side by side the water line freezes
The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker connection keeps cracking and flooding my house
sometimes ice makers get iced up inside the fill mechanism and causes this to happen. Have you tried defrosting the freezer? This may take care of your problem.
Mar 13, 2017 | Frigidaire FRS6R5EMB Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
306 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
