Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
What is the blow dryer trick and what is it used for?
What is the blow dryer trick , how do you do it and what problem is it used to fix?
  • madd2k1 Jan 24, 2009
    Worked perfectly~! Thanks!!
Where can i find the blow dryer trick
Posted on Feb 15, 2010
  • lilbmack14 Feb 15, 2010
    WHERE CAN I FIND THE BLOW DRYER TRICK
  • 537 Answers
Check this link:
http://www.complaintsboard.com/complaints/2060/page/2
Posted on Jan 23, 2009
My monitor takes long time to come on why
Your power supply board has a "flakey" capacitor on it.
It will soon fail, I can guarantee you that. The replacement component is likely less than a dollar, but figuring out which one it is can take a bit of sleuthing.
Try blowing hot air from the hair-dryer into the back when powering it on, it should speed things up a bit.
The solution is to have it repaired. The "Fixya" here is DON'T TURN IT OFF, because then you won't have to worry about it turning back on!
I have a monitor that I have been using the hair-dryer "trick" on for YEARS.
If I reboot the computer, and the monitor is already hot, I have to wait for it to cool before the hair-dryer trick will work again.
Have fun!
Feb 28, 2015 | Computers & Internet
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
Whirlpool dryer ler7646eq1 will not heat
First the most obvious and you've most likely covered yourself look at the lint trap/if clogged clean thoroughly with vacuum cleaner pull out lint trap and **** up as far as deep as you can get some of the lint that you don't see and believe me there's a ton depending on your exhaust/vent type . Next go outside check the vent attached to the outside of home for clogs/lint buildup lastly here's a trick I've personally used SEVERAL TIMES on my old ge dryer if you have a LEAF BLOWER pull dryer out of the way and next go outside remove exhast vent usually 4 phippls screws going out next remove vent/trap outside go back inside and use the leaf blower to blow out all of the lint caught in the vent tube your be surprised how much was in there. HOPE this quick fix addresses your dryer issue if not its most likely the dryers thermostat they're fairly cheap online. Just trying to save you a buck friend. Have a good day Ryan in Minnesota
Oct 17, 2012 | Whirlpool Dryers
I need to replace the heating element... any tricks to this?? Thanks.
Unplug the dryer, take the time to clean all the link out and the hoses, if retaining clips are used assure they are in place. If you have a vacuum, with a blow cycle use it to clean out all stubborn lint. And last don't drop the element on the floor as it is susceptible to damage. Good Luck!
Douglas
Jan 28, 2011 | Danby Dryers
Air is coming out but no heat
Hi Joe,
For a free do-it-yourself checklist, click on my username and scroll down on my profile til you find my tips and tricks on trouble shooting gas dryer heating problems. Hope you find it helpful.
May 16, 2010 | GE Profile Harmony DPGT750EC Electric...
The Neptune has been taking forever to dry
when a dryer takes along time to dry you have a venting problem,, icant telll u if lint is clogged up inside the unit,, or lint is inside you venting, or if lint is cloggged up inside you vent piping through the hose,,, this is common if you have a long vent distance before it exits the house, or possibly the vent is kinked and your dryer is pushed back to far.....
to check undo the venting to back of the dryer and run a load of clothes with no venting hooked up if this drys faster than u know that where your blockage is occuring......
A lil trick also check outside when running you should feel air blowing
also use a leaf blower from inside put in hole of ducting andd blow that line out clean it out hope this helps feel free to leeave me a testimonal leetting me know how things went ...k take care good day
Feb 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Dryer has power, just buzzes, does not start to spin
sounds like you need a new motor .or PAY professional help .
Jan 28, 2018 | GE DPSB613GDWW Gas Dryer
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
596 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
