Question about Brother HL-2070N Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
After pulling out a paper jam the "paper" light on my Brother HL-2070N began flashing. I opened all the accesses and found no more paper. I checked the toner and paper size and everything seems fine. I powered it down. Upon powering up it imediately goes to default and the light begins to flash again. Is there a sensor that I might have broken or maybe that got stuck? Any ideas?
  • 2 more comments
  • Anonymous Jan 26, 2009
    I have the same problem. Solution #1 didn't fix the problem. Thanks for your help.
  • avanagtmael Feb 06, 2009
    Paper light keeps flickering even after taking out cartridge, adding paper and removing stuck paper. Path seems clear but it won't allow me to print
  • Anonymous Feb 15, 2009
    I turned off printer right after a page printed and now, when the printer is on again, the Paper button will not turn to green, and I cannot print.
  • dukeduster Mar 02, 2009
    As soon as I turn on printer it goes straight to the flashing paper led. Cleaned corona wire cleared all jams and still nothing? Please help
  • 13 Answers
Http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Posted on Apr 21, 2010
    New Friend:
    Problem Solver:
  • 5 Answers
Had a paper jam due to a ream of paper left lying on top of the machine. Opened all covers and removed 3 jammed sheets. they were all complete, no tears. Paper light would
not go out. Tried holding go button when powering up, then pressing it again. Machine seemed to go through its reboot
but light is still on. Removed and inspected toner cartridge and roller, all look good. There is a sensor lever on the gate inside the rear cover. It is in the centre, and it connects via a small plastic rod to a latch or something on the right, when viewing from the rear. This rod has a small quadrant halfway
along it that is supposed to be located in a slot in the clear plastic part of the gate. It was not in position, which was evidenced by the fact that the rod was curved, instead of being straight as it should be. With the assistance of a thin bladed kitchen knife I was able to properly relocate it and the printer
works as perfectly as it always has.
Posted on May 02, 2013
  • S Johnson Jul 31, 2013
    YEAH!!!!!!! Fixed mine :-) I LOVE you man!!!!!!! I was going to throw it out on to my front yard!!!
I pulled my hair out on this one. I was printing mailing labels using Word 2010's mail merge. Finally I got things going by printing to a virtual printer I had (FinePrint) and then to the printer. Any time I tried to print directly to the printer from Word I got the paper light. Go figure?
Posted on Dec 17, 2010
I had the same problem and ended up changing paper. Working well so far.
Posted on Feb 03, 2009
  • 142 Answers
Remove the drum and cartridge alsp and check for crumpled and torn debri, and also paper tray area.
Posted on Jan 25, 2009
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 12, 2010 | Brother HL-2070N Laser Printer
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
2070N brother printer has flashing paper light
There is a paper jam inside your printer . Clear those paper , your problem will be solve.
Jan 10, 2009 | Brother HL-2040 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
HL-2070N paper LEd flashing
most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Oct 18, 2008 | Brother HL-2070N Laser Printer
Flashing paper light
there is a sensor maybe is stuck
Apr 06, 2008 | Brother HL-2070N Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Logo
2,463 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
