Question about Pioneer PDP-425CMX 42 in. Plasma Television
Pioneer plasma 42 inch tv won't turn on. power runs thru dvd. remote is sending signal and dvd has power.
  • mike_schmalt Jan 23, 2009
    thank you I found power button have no idea how it was turned off and looked all over TV and never even knew button was there.
  • 4 Answers
There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Posted on Jan 23, 2009
Trying to put on closed caption on gateway tv 42 inch-a large black screen appears
don't know if CC can be used when watching a DVD. seems to me that it would cause a conflict on the display where the dvd is sending the image which is really not part of the TVs input control options.
CC is usually related to the digital signal from signal broadcasts and not video images coming from an external source. if it was controlled i would think it would be from the dvd remote controller. not the tv.
Oct 14, 2012 | Gateway FMC-901 w/ 42-inch Plasma TV...
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
My LG 32 inch tv will not pik up signal from DVD
check using other player ..
to conform wether the tv line is clear...
Sep 28, 2009 | LG MZ-42PZ14 42 in. Plasma Television
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
AKia pdp-4249g
I HAVE PROBLEM,THE SCREEN SAYS AUTO SELECT SEARCHING,THEN NO SIGNAL FOUND THEN THE TV TURNS OFF BY ITSELF
Apr 16, 2008 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
PIONEER PLASMA NOT TURNING ON
common problem power supply need replacement
Oct 25, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Pioneer PDP-425CMX 42 in. Plasma Television Logo
271 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
